Results 1 to 3 of 3
Thread: Washers not working
    Regular Member Padster72's Avatar
    May 2007
    Marchwood
    Vehicle : Insignia
    Trim : 160 SRI Nav
    Engine : 2.0 CDTI
    Year : 2010
    Default Washers not working
    I have very little/no pressure coming from the rear washers, and a weak pressure from the drivers side front washers. Having looked on here, it has been suggested I clean the filter.
    I followed the How 2 which is posted on here, and upon removing the rubber filter grommet thing, I discovered there was no filter within it!
    Next, I dismantled the pump, and blew through the 'white' end cap, and found that there was air freely going through one side, but not the other. Research has told me this end cap contains a diaphragm.
    Any ideas what to do next? Would the diaphragm be causing my problems, or is there something else I need to try?
    (Oh yeah, its a 53 plate 2.2 Elite - non direct)
    11 Post(s)
    The rubber grommet is the filter.
    Likewise, when I stripped mine down, I found you can only blow through one hole.
    Have you tried putting the end of the pump into a jug / cup of water and then getting someone to operate the screen washer for you?
    May 2007
    Marchwood
    Vehicle : Insignia
    Trim : 160 SRI Nav
    Engine : 2.0 CDTI
    Year : 2010
    OK, will try that one tomorrow.
    Oh, when I said about the grommet, that is all I found, just a small rubber grommet fitted in the top of the washer bottle. Seemed more like a rubber gasket tbh
  1. Windscreen washers stopped working
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2011, 18:10
  2. window washers not working and
    By wiganrl in forum Vectra C / Signum Troubleshooting
    Last Post: 28th January 2011, 23:48
  3. Washers stopped working
    By Marky in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2009, 16:22
  4. Washers not working :(
    By Diet1985 in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2009, 18:10
  5. washers are working weheyeeee
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2006, 21:00
