Thread: 2.0 dti
    Regular Member dervb's Avatar
    Jun 2007
    Thornton merseyside
    Default 2.0 dti
    Hi peeps,
    Giving the old oil burner a going over at the weekend as i am looking at doing a single tank bio conversion,properley this time.
    when i noticed a strange noise coming from the front of the engine starting at 1500 rpm onwards, sprayed some free it round pulleys /tensiner etc to no availe.
    no loss of power or spanner light very confusing .
    might take egr and inlet out and give it a clean you never know....
    regards bill.
    Regular Member suggs1971's Avatar
    east cleveland
    What sort of noise is it m8.
    Jun 2007
    Thornton merseyside
    stripped inlet and EGR valve 2 bits cleaned out,replaced leak off pipes.
    Noise is still there....hard to describe ,if it was a pulley needing a lube ,gr8.but it isnt,got a sneaky it might be the pump.
    no loss of pwr or spanner lights etc,very strange.
    anyways off for ankle op 2moro so driving the vec for a few weeks.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    When was the oil last changed and what was used? I had the same problem with my 2.2dti when I first got it but after switching to 0W-40 fully synthetic the noise went away. I was assuming that the wrong grade of oil had been used causing the chain tensioner to be lazy
    Jun 2007
    Thornton merseyside
    back home now , no driving for a good few weeks....
    hi matey,oil change last done on annual service december at duerdons vaux formby......
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Could it not be timing chain tensioners ? These are common on Dti engines
    Jun 2007
    Thornton merseyside
    thanx 4 the ideas lads ,when i am a bit more mobile (on my feet) i will take a closer look.
    thanx again....
