Thread: diesel filter
    Regular Member G4GAV's Avatar
    Bristol
    Default diesel filter
    After some help , iv just changed the diesel filter this afternoon, done as my mate at the garage said attach filter to the housing fill the unit with diesel put on the seal then top and tighten. put back on car and turn over and let idel and do not rev .... afetr a min or two should be ok to drive....
    my problem is the car wont turn over any more, turned over 2 times and then died on me running for no longer than 15 seconds. ?
    im confused, any body help please .....
    Aldermaston (Berks)
    It would have fired briefly due to diesel being left in the lines/injectors. You have back filled the filter housing-now you need to bleed the lines by cranking for 5 secs then leave for 5 secs repeat this process until it fires into life.
    Bristol
    done this but now another problem, the car spanner comes on and it goes into limp mode. never done this before but when i picked the car up just over a week ago it had the spanner light on any way but still give the power. when i got it running after fitting all back together it wouldnt allow me to go over 2000 revs? is this right ??
    I see you have a 1.9 cdti so there was no need to fill the filter housing with fuel as there is a lift pump in the tank on the 1.9 models. The correct way to start the cdti engine after changing the fuel filter is to turn the ignition to position 2 for ten to fifteen seconds switch off and repeat the process switch off again, the fuel system should then be primed and you should be able to start the engine normally. Just a thought, have you put both of the electrical conections back on the fuel filter housing.
    Regular Member mikey362's Avatar
    Sheffield
    thanks guys this got my dti running again and i got the spanner light to but only for about 3 seconds
    mike
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. Diesel Filter - Help
    By houston in forum Engine & Drivetrain
    Last Post: 22nd August 2011, 15:11
  3. K&N Air filter for a diesel
    By shamus5178 in forum Diesel Engine related
    Last Post: 16th February 2010, 21:35
  4. where is the diesel filter???
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2009, 22:26
  5. Diesel Filter?
    By thewww2 in forum Engine & Drivetrain
    Last Post: 21st April 2006, 21:26
