hi all i have asked vx if its poss to fit the twin rear seats to my facelift exclusiv veccy bt they just stare at me as i would like to try and fit the fridge to the rear if i can fit th seats.thanks dee.
I suppose anything is possible, but you'd need the whole rear bench setup including the rails and whatever base they sit on as the whole thing is completely different mate. Find one at a scrappies and you're on to a winner...
I don't think Signum seats from a scrappy will help you - there won't be the right fixings on your floorpan to bolt them onto.
If it's the Travel Assistant you're after, I believe that can fit the existing Vectra seats, you just need a different base for it rather than the Signum base.
Hence why you'd need everything, including the rail mounts and whatever else attaches them to the floorpan. As you say, everythign is different, but with a bit of welding anythign is possible...
There IS a travel assistant base available for the Vectra, but you have to buy the TA with it and I've a feeling it's horrendously expensive, if it's still available...
Danboy would be a good place to start with part numbers and prices for that aspect...
thanks for the speedy reply guys much more helpful than vx.aye there is a signum with the same cloth as my exclusiv in the scrappy and was gona buy them and then down te line get a black leather with red alacantra centre to match my paint.
With enough time and money anythign can be made to fit mate - it jsut may require some work to the chassis on the rear bench first. Make sure you get EVERYTHING from the scrappies that's even remotely attached to the rear seats and you'll have given yourself a good start...
