Thread: signum seats fitted to hatch?
    belfast
    Default signum seats fitted to hatch?
    hi all i have asked vx if its poss to fit the twin rear seats to my facelift exclusiv veccy bt they just stare at me as i would like to try and fit the fridge to the rear if i can fit th seats.thanks dee.
    I suppose anything is possible, but you'd need the whole rear bench setup including the rails and whatever base they sit on as the whole thing is completely different mate. Find one at a scrappies and you're on to a winner...
    Regular Member Jezzy's Avatar
    S.E
    I don't think Signum seats from a scrappy will help you - there won't be the right fixings on your floorpan to bolt them onto.
    If it's the Travel Assistant you're after, I believe that can fit the existing Vectra seats, you just need a different base for it rather than the Signum base.
    Hence why you'd need everything, including the rail mounts and whatever else attaches them to the floorpan. As you say, everythign is different, but with a bit of welding anythign is possible...
    There IS a travel assistant base available for the Vectra, but you have to buy the TA with it and I've a feeling it's horrendously expensive, if it's still available...
    Danboy would be a good place to start with part numbers and prices for that aspect...
    belfast
    Default thanks!!!!
    thanks for the speedy reply guys much more helpful than vx.aye there is a signum with the same cloth as my exclusiv in the scrappy and was gona buy them and then down te line get a black leather with red alacantra centre to match my paint.
    Quote Originally Posted by vectrac1988 View Post
    With enough time and money anythign can be made to fit mate - it jsut may require some work to the chassis on the rear bench first. Make sure you get EVERYTHING from the scrappies that's even remotely attached to the rear seats and you'll have given yourself a good start...
  1. Has anyone fitted heated rear seats in a signum?
    By signum_rob in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2012, 19:13
  2. Hatch into estate seats question
    By marc1 in forum Styling
    Last Post: 4th January 2011, 07:57
  3. Cross hatch grille fitted
    By PAULMAC77 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2009, 09:12
  4. rear seats saloon to hatch
    By 22ultra in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2009, 23:04
  5. Hatch & Estate rear seats ?
    By Green Growler in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2007, 16:59
