Results 1 to 10 of 14
Thread: Clicking from rear after pad replacement
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Default Clicking from rear after pad replacement
    I changed my rear pads recently and have noticed a clicking noise when the wife drives off. I can't hear anything from inside the car and have checked the pads and can't see anything obvious. Any ideas???
    Full Member spennny's Avatar
    Blantyre
    Is there not a stone stuck in the tread ?
    I had this last week after waving the Mrs off in my car
    Regular Member Exclusive BV's Avatar
    West Midlands
    quite common when changing direction (ie from backwards to forwards and vice versa) it could be the pads re-seating themselves.
    Is it only happening under breaking?
    @home
    Engine : 1.9 CDTi
    Quote Originally Posted by spennny View Post
    sounds too loud for it to be something in the tyre but will check anyway.
    Quote Originally Posted by Exclusive BV View Post
    Happens when driving off without any braking.
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Mine did the same when i changed the rears.
    I did the usual tyre checks for stones etc. but found nothing.
    It went away after a couple of days and hasn't come back.
    Glasgow
    Are they cheap pads? Ive had this problem before after getting cheap budget pads fitted, not a perfect fit. Replaced them with GM ones and problem solved.
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Re grease the rears... Mine tapped under braking etc (before biting) after i cleaned them a little too well before painting callipers. Re-greased and nothing since...
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    I had a clicking from my fronts after changing them. Today I took them off and wiggled the offending caliper. Compared to the other side it was fairly loose. The only thing thats stops them moving is the spring so played with that and no more noise. So check the springs are tight.
    @home
    Engine : 1.9 CDTi
    thanks guys, will give them suggestions a go tomorrow.
    PS They are GM ones.
    May 2006
    scotland
    My rears have done this since K Fit replaced them. I took them back and they fiddled with something that made the noise go away for a few days but it did return. I suspect they fitted pattern brake pads that are not exact size as OEM and this is the cause. It is like the pads are snatching and moving slightly just when the brakes are applied. Only notice the noise at very slow speeds, probably they always do this but the other noises at higher speeds mask it.
  1. rear pad replacement
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2011, 19:00
  2. Rear Pad Replacement
    By Fozman in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2009, 21:38
  3. rear pad replacement
    By campbell1987 in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2009, 20:07
  4. Rear Pad replacement
    By phildjohnson in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2009, 20:40
  5. Clicking Rear Breaks
    By scottymf in forum Suspension, Wheels & Brakes
    Last Post: 3rd August 2008, 17:58
vectra c estate rear brakes clicking stop when braking
