Results 1 to 10 of 14
Thread: Key Fob
    Scunthorpe
    Default Key Fob
    I dont suppose anyone knows the price of a 3 button flickout key fob from Vauxhall do they as i only have one key and could do with a spare!!!
    Regular Member bunsen1's Avatar
    suffolk
    i dont know the prive but i no its not cheap, my guessing would be £100 mark but maybe more. i could be wrong but i do remember a while ago trying to find the price out for an nissan key from nissan and well that was about £90 or more
    Depends on the dealer! It should be somewhere around £60+VAT last time I saw a price. May be a tidge more but not much. Then there's the cost to program it to the car - again it depends on the dealer. It only takes 5-10 mins to do it so should cost £15-20 + VAT but some dealers take the pee and will charge half an hour labour for doing it!, or a minimum Tech 2 charge of an equally expensive amount.
    Scunthorpe
    Cheers i'll watch out for that. Either way its going to cost a fortune then!!!
    Regular Member Innes's Avatar
    Plymouth
    I bought my blank key off ebay (for £15 and key cut for £10) and coded it myself. From inserting the blank key, firing up the software and pressing the correct buttons to finally getting a coded key takes about 30-45 seconds!
    Its a shame the dealers dont charge by the second otherwise it would have cost under £1!
    prestatyn
    was your key new as i've hear you cant program used keys
    prestatyn
    not bad price cut,if somebody has opcom or tech2 close to you then total cost £50 plus a few bears for the guy with software compared to stealers price
    http://cgi.ebay.co.uk/VECTRA-C-SIGNU...item3a5b3797ec
    Regular Member DaveW555's Avatar
    Cannock
    There's a bloke on ebay does them cut for 45 quid then you just need it programmed (thats assuming you've got the key code of course but the dealers should give you that information FOC)
    prestatyn
    link above,its ashame you cant reprogram used keys but what i dont understand is if you change the ecu do you have to change the lot then ie ecu,key reader and key on the vectra c,when i had a vec b light was flashing and had to replace ecu, key reader and key to get it to run,what if you reset the ecu to delivery status then tried reprogramming a used key
    Cannock
    Im pretty sure you'd have to change the lot unless you bought a brand new ecu from vx and had everything programmed to it
