Thread: button on the door
    Regular Member vectra_'s Avatar
    australia
    Default button on the door
    on the passenger door and on the drivers door theres a boot button, but when i push it theres a beep sound...and cant open the boot from the buttons on the doors
    Scunthorpe
    Quote Originally Posted by vectra_ View Post
    Its not supposed to open the boot. It beeps to tell you it has unlocked the boot. You still got to get out the car and open it with the button on the boot!!!
    australia
    dammmnn ((: my bad...lol
    so thats sposed to lock the boot
    Scunthorpe
    Unlock!!! I've got my car set to lock everything when i drive away so it might lock it aswell. You'll have to try it!!!
    Alternatively you should have a boot button on your key fob. That does the same and just unlocks the boot!!!
    [Ex]Admin Duncan's Avatar
    As Tom said it simply unlocks the boot, enabling you then to go and physically open it. Pushing the button again doesn't lock it again, it locks either by you using the lock button on the door before driving off, or it will lock automatically something like 30 secs after being closed/unlocked.
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    it does indeed lock after 30 secs or so on its own. so dont do what i done b4 & leave your keys in there
    Yep, that's about the only way that you can lock your keys in the car - as other guys have found out!
    Unlock boot (only) from fob, get stuff out/put stuff in, put down keys in boot in the process, close boot, 30 secs later boot locks, realisation as it dawns what's happened -
    Scunthorpe
    I'll bear that in mind!!!
    Mental Note to Self: Never put keys down in car boot!!! Lol!!!
    Worcs/Staffs/Westmids (ish)
    You'll find also, that if you have the engine running after parking up somewhere, the boot will refuse to open if you don't press the button on the door switch panel.... It's meant to be a security feature
    WGAF#5
    it also puts on the no plate lamps to let you know its "unlocked" will remain unlocked for 10 minutes if not opened before relocking
  1. electric boot, drivers door button
    By felix_19 in forum Bodywork & Interior
    Last Post: 11th September 2013, 09:28
  2. Replies: 32
    Last Post: 2nd January 2013, 02:18
  3. central locking door button stopped working
    By MURDO in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 22:47
  4. Drivers side door lock internal button
    By slipperysam1984 in forum Vectra C / Signum Troubleshooting
    Last Post: 12th August 2009, 22:25
