Results 1 to 3 of 3
Thread: X-tra cooler for transmission oil on V6 CDTi
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Default X-tra cooler for transmission oil on V6 CDTi
    Hi Guys..
    At last my garage got around to get the oil changed and mounting an extra cooler on my V6 CDTi....
    Is has now run 105.000miles and the transmission fluid was black. But not any water or anything in it though. I don´t think it have ever been changed before.
    The cooler is 35cm wide 20cm high and 2 cm thick. The cooler (Black thing ) is placed in front of the AC cooler.
    The gearshifts are much smoother and you can feel the car running better.
    The garage who carried out the work are specialist in autobox´s and GM car in general. So no worries there..
    Cheers mates..
    Sydney, Australia
    Mate, is it possible for you to post some more pictures of the mounting points?
    Thanks!
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Pictures are not that clear.
  1. Suspected oil cooler issues 1.9 cdti 150
    By jay w in forum Engine & Drivetrain
    Last Post: 22nd October 2012, 22:25
  2. 1.9 cdti 120 (8v Z19dt) egr cooler gaskets
    By 2wheelstu in forum Engine & Drivetrain
    Last Post: 7th May 2012, 00:59
  3. Vectra Cdti transmission oil??
    By mossy2432 in forum Vectra C / Signum Troubleshooting
    Last Post: 21st May 2011, 16:20
  4. Automatic Transmission problem in 1.9 cdti
    By devrim in forum Engine & Drivetrain
    Last Post: 25th April 2008, 11:07
  5. Vectra V6 CDTi Auto -Towing Limit/Oil Cooler
    By solarvec in forum Engine & Drivetrain
    Last Post: 20th March 2008, 15:15
