Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: using 6th gear
    Aug 2009
    sheffield
    Default using 6th gear
    hi,since fitting 19" alloys , the gearing is very high, and i don,t use 6th gear as much as when i had 17" alloys. does the speedo alter as well excellent on the motorway as the rev,s drop in 6th.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    what size tyres did you use... as it shouldt change that much.
    WGAF#5
    post up the initial tyre / rim size
    and your new tyre/ rim size then we can calculate the difference - but TBH i will be suprised if its more than 5-7mph different overall
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by cranny 27 View Post
    I thought my gearing was higher since putting 19's on as well,i thought it was just my imagination
    It's your imagination, the rolling circumference is virtually the same
    When changing tyre wheel sizes the profile typically gets higher, get it wrong and all kinds of problems begin
    However, from memory, once you go to 18" and 19" wheels you need to have the car TEC2 to change the tyre specification so that the ABS sensors don't get confused
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    That maybe so,but i'm sure it doesn't pick up in 6th so quick as it did before
    Full Member Big Sig's Avatar
    No you dont. 215/50/17 are exactly the same rolling diameter as 235/35/19.
    So if the wheels still go round at exactly the same amount whats to confuse the abs sensors???
    http://www.miata.net/garage/tirecalc.html
    There is a list of tyre specifications within TEC2, from memory if you use some of them you need to make the change
    I had to do it on changing from 215/50R17 to 225/45R17
    The difference is minimal, but once the change is made the car responds much better
    Regular Member Marcosuk's Avatar
    Fife
    watching with interest
    [Ex]Admin Duncan's Avatar
    Sorry, but rubbish. How on earth will the car respond much better by altering that value in Tech 2?! All that does is bring the speedo back into line for the (very) small difference in circumference between those two sizes. It's something like 2% difference in circumference between those two sizes so the difference on the speedo will be minimal.
    When I changed from 215/50/17 to 225/45/17 I didn't bother with the Tech 2 tweak - certainly wasn't paying a dealer through the nose for something that didn't matter. All it meant was that my speedo over-read slightly more than it would've normally. When I changed from 225/45/17 to 225/40/18 it changed slightly again i.e. over-read a tidge more so that now my speedo would overread by around 4mph at 70mph. As I had Vaux-Com at that point I made the adjustment and brought it back in line to it's normal small amount of over-reading which it would be as standard.
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
what speed should i use 6th gear Vectra c
