Results 1 to 2 of 2
Thread: Removing gear selector
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Default Removing gear selector
    Does anyone know if the gear selector mechanism can be removed from the F40 gearbox with the gearbox still in the car and without disturbing anything? i.e is it a case of undo the 3 bolts remove it, grease it up and replace it like the early boxes on the mark 2 cavaliers were?
    any advice appreciated as the linkage really stiff on my sisters vectra.
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    I'll PM you the details in a bit, torque setting's etc.
    But from memory it's basically removing the reverse switch connector, remove three bolts, then remove the selector tilting it to the left side of the car as you do it.
    Obviously check for any loose debris around the openeing before you remove it as you don't want anything dropping into the box.
    Upon refitting you'll need a new o-ring p/n 93182244
  1. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  2. Gear selector problems
    By suj786 in forum Engine & Drivetrain
    Last Post: 20th March 2011, 23:31
  3. Gear knob selector maybe ?
    By ibrazier04 in forum Bodywork & Interior
    Last Post: 22nd April 2010, 19:50
