Thread: 3.2 erratic idle
    West Wales
    Default 3.2 erratic idle
    My LPG converted 3.2 won’t idle properly when it starts up on petrol and is showing all the symptoms of fuel starvation. Fault code 0170 is showing up and the EML is on. It runs fine once switched to LPG after a minute or two. The fuel computer is reporting an average mpg of 50 rather than the usual 30 though actual LPG consumption is unchanged. This problem coincided with a service of the LPG system. Initially I thought that the T pipe connections between the throttle vacuum diaphrams had been disconnected but they are fine. Any ideas?
    Regular Member DaveW555's Avatar
    Cannock
    Fault Code 0170 is usually the MAF sensor, try taking it off and giving it a good clean with some electrical contact cleaner, the only other thing I can think of that would cause the problem you're having is one of the lambda sensors playing up. Hope this helps Good luck with it.
    West Wales
    Default 3.2 LPG erratic idle
    Thanks for that Dave. MAF cleaned but no change. This fault has now become more LPG specific. The car recently ran out of LPG. After running a few miles on petrol and then restarting over a 2 day period on petrol it started and idled normally. Topping up the LPG tank and going back to petrol starting/LPG running has brought back the fault. Knowing little about the LPG system I am wondering whether there is a valve/switch which is sticking causing the car to try to start on the fuel it was last running on?
    Full Member Big Sig's Avatar
    That would be a job for a lpg specialist.
  1. Z20NET Rough Erratic Hesitant Idle Issues...... Help??
    By greenmonster in forum Engine & Drivetrain
    Last Post: 9th July 2012, 16:03
  2. Erratic CANBUS
    By johnmac in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2009, 22:30
  3. Erratic Metalic Noise/Lumpy Idle
    By barkzz in forum Engine & Drivetrain
    Last Post: 28th April 2009, 20:06
  4. massivly erratic 3.0l
    By Adamdavi3s in forum Engine & Drivetrain
    Last Post: 7th August 2008, 16:09
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
