Thread: Facelift N/S/F Bulb
    wolverhampton
    Default Facelift N/S/F Bulb
    Hi all,
    I am trying to change my n/s/f dipped beam bulb on my facelft 120 cdti.
    I have got access to to rear of the bulb ok.
    I just can't see how to get the bulb out of the headlight!
    The manual says take it to the dealer.
    I have looked through previous threads but they all just seem to say it just pulls out.
    I cant see any clips and the bulb wont budge if i pull at it.
    Am i missing something?
    The only thing I can see are 4 tiny torx head screws around the bulb, am I ment to dissmantle it?
    Cheers for your help.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    it does just pull out once you have unscrewed the back!!! might be a tad stiff but it does come out
    wolverhampton
    Im afraid if I pull at it something will break or am I just being a little girl!
    If I just pull it what actually keeps it in place then, as there are no clips or twist motion?
    Aug 2009
    sheffield
    hi,just give it a good pull . push fit. pull on wires/block thats pushed on bulb. then put new bulb on block and push back in. hope this helps. big girl ha ha ha
    Feb 2007
    its in a groove which is the same shape as the light and when pushed back in it sort of sucks the light in which keeps it in place!!! come on ya big girl give it a pull lol
    Sodding Typical on Sea
    I found it a tight fit I found that by almost angling it back from top to bottom it released OK then refitting I knew how to get the bulb to lock and it was far easier. I was also a bit afraid I would break something
    Regular Member kevcdti's Avatar
    North east
    The dipped beam twists out,dont just pull it unless you mean the sidelight bulb which just pulls out
    Regular Member fingers66's Avatar
    Carpe Diem
    Quote Originally Posted by kevcdti View Post
    He has a facelift, the bulbs pull out, unlike the preface that twist out.
    go on you big girl, give it a pull.
    Admin plasma's Avatar
    On the Forum
    271 Post(s)
    Engine : 150
    Mileage : 74000
    there are TWO types of H7 fixings on these bulbs. One type is a twist lock cover that holds the bulbs in place and the other is as said a pushfit which then automatically locks it in place.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    wolverhampton
    Thanks all, a gud tug got it out. Not that much of a litle girl!
    The only thing is the new blub has gone in, but feels slightly loose.
    Should it be as tight as the old one. I think after driving over some bumps it may fall out.
  1. Vectra facelift bulb?
    By GAV_SRI in forum Vectra C / Signum Troubleshooting
    Last Post: 21st April 2012, 21:35
  2. For Sale: Bulb holders pre facelift
    By The Gas Man in forum Parts for sale
    Last Post: 21st January 2012, 22:49
  3. Facelift Bulb replacement
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2009, 08:54
  4. Which bulb types for facelift?
    By muffking in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2009, 15:45
  5. facelift bulb replacement
    By mat osborn in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2009, 19:51
