Results 1 to 10 of 16
Thread: Emissions light on after EGR clean.
    Regular Member StarDust2k5's Avatar
    Newport, Wales
    Default Emissions light on after EGR clean.
    As title says, removed and cleaned out the EGR and now my emissions light is on and it wasent previously. any ideas? got a funny feeling i fudged the EGR when cleaning it.
    Newport, Wales
    btw i mad sure all gaskets etc where replaced with a good seal and the valvle itself was opening and closing freely without any soot caught in it.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    what's the mileage on your motor
    i cleaned mine a few times, and it helped for a while -- but at 85,000 miles i got a new one. definitely fixed things for me.
    might be just time for a new one, cleaning doesn't always work.
    Newport, Wales
    65k on it now. thing thats got me tho is the light is only on since i cleaned it and had never come on before. also seems to be down on lots of power bellow 2000 rpm and then fine above it since the clean, but it could just be me.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    Down on power below 2000rpm is the exact symptom i was having.
    Could be it has seized now, strange that's happened after cleaning it, but you may have dislodged some soot.
    I'd give it one more clean and make sure the mechanism is working while doing so.
    Newport, Wales
    yep going to pull it all back off tomorrow and try to figure out whats up with it, hopefully can avoid getting a new one as it would make this a rather expensive mistake as it worked fine before i pulled it all apart.
    guess lesson is if its not broke dont fix it yet again.
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    double check the electrical connector... if can look like its on but sometimes doesnt sit right...
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Quote Originally Posted by Hideous View Post
    Could be it has seized now...
    Sounds about right, the light is usually when the EGR is closed, so there's either an electrical issue, or its stuck.
    caistor
    so blank it off lol
    Newport, Wales
    had taken it for a few spins earlier to try and get the light to go out but nothing. started the car now and took it for a blast up to 120mph down a private road of course and no light.
    still doesnt like to pick up speed from under 2k rpm in anything but 1st and 2nd tho... could just be me noticing it now that im looking for it but never seemed this bad before.
  1. Emissions light
    By iain.condliffe in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2013, 10:07
  2. Emissions Light Help!
    By LadOnTractor in forum Engine & Drivetrain
    Last Post: 24th July 2011, 08:53
  3. emissions light
    By trickster75 in forum Engine & Drivetrain
    Last Post: 19th May 2011, 21:10
  4. Emissions Light
    By BigKev1970 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th September 2007, 22:16
