Results 1 to 10 of 14
Thread: Changing rear brakes tomorrow, any tips?
    Regular Member SRI456's Avatar
    Northants
    Default Changing rear brakes tomorrow, any tips?
    Im going to fit new rear discs and pads tomorrow, which looks quite straight forward in the haynes manual, but it does suggest i clamp the flexi hose and open the bleed nipple before i compress the piston, is this necessary as i have never done this on my previous vauxhalls, i usually just release the top on the fluid resevoir, also do i need to replace the caliper bolts for new ones, if so does anybody know what i need to ask for at the parts counter.
    Any other tips welcome.
    Cheers Keith
    Oct 2006
    southampton
    15 Post(s)
    Yeah, go down the pub and spend a bit more time thinking about it and do it next week
    [Ex]Admin Duncan's Avatar
    I've never clamped the hoses and used the bleed valves, simply done what you've done and released the reservoir cap when I've wound the pistons in.
    You've got a rewind tool I assume?
    Caliper bolts - strictly you're meant to replace them but if you clean up the threads and put on fresh locking compound you'll be fine.
    If you need the part numbers for the bolts, if you thought you'd prefer to get some, and want the torquing values of the bolts then let me know.
    Northants
    If i can get away without spending more money, im happy with that, so i'll clean the threads up, can you recommend a good locking compound.
    I use a Loctite one - blue stuff in a little Pritt stick type tube. I can go and look at the tube and get the specifics if you want, but basically a general purpose locking compound.
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    i know that duncan has mentioned put not sure if u noticed or not but remember to wind the pistons back in not just squeez them in.hth
    Northants
    Yep, wind them not squeeze them, im trying the long nose plyers trick as suggested in haynes, do you think halfords sell the loctite?
    Yep, Halfords should sell it. I'm sure that's where I got mine from.
    Northants
    Cheers guys
    Regular Member DaveW555's Avatar
    Cannock
    Dont use cheap discs and pads spend the extra on some oem parts, they'll last longer and work better!
  1. Changing Front Wiper Motor Tips?
    By Kev_G in forum Vectra C / Signum Troubleshooting
    Last Post: 25th July 2011, 10:36
  2. Changing sri exhaust tips
    By craig1989 in forum Styling
    Last Post: 26th May 2010, 19:36
  3. any tips on how to cut the rear valance to show my exhaust tips
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 18:58
  4. How2,hints,tips, on bleeding brakes plz
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 12:21
  5. Changing rear brakes on estate
    By mainand in forum Suspension, Wheels & Brakes
    Last Post: 10th August 2007, 11:39
