Thread: Engine Oil
    Regular Member KSD's Avatar
    Aug 2007
    Cupar, Fife
    Default Engine Oil
    Anyone reccommend a good oil for the 1.8 VVti?
    Regular Member old cruiser's Avatar
    slough
    vauxhalls own is as good as any I find mate and yours I guess would be 5W30 fully synthetic.
    Cheers Pete
    Regular Member DaveW555's Avatar
    Cannock
    Its gotta be 5w/30 or 5w/40 fully synthetic in that matey and do the oil change every 10k instead of every 20k, them engines like clean oil, My father in law has just bought an astra with that engine its only done 10k and its having its first service next week. Its something to do with the oil feed to the vvt unit that doesn't like dirty oil and it has been known to cause problems. Hope this helps.
    Regular Member Exclusive BV's Avatar
    West Midlands
    DaveW,
    does it make any difference whether it's 30 or 40?
    Would your choice depend on how much mileage it's covered?
    Will be giving mine it's first change (under my ownership) soon and I want to make
    sure the right oil goes in.
    (apologies for the side question, not trying to hijack)
    Cannock
    Autodata lists everything from 0w/30 or 0w/40 to 10w/40 for that engine. It doesnt really matter which you go for but I'd definately stick to 5w/30 or 5w/40 fully synthetic in that.
    11 Post(s)
    Vauxhall themselves recommend 5w/30
    http://www.vauxhall.co.uk/vaux/owner...do?method=view
    london
    IMO , i think 5w40 Is slightly thicker at operating temperature than 5w30.
    After comparing the two, i now use 5w30 because it gives me better mpg and i think VX recommends 5w30 on 2.2 engines
    Cannock
    Vx reccomend 5w/30 on pretty much the whole range, On the VVT engine its best to stick to that really and change the oil and filter every 10k rather than the 20k Vx recommend.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
