Thread: Intercooler
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Intercooler
    Ok, i have upgraded my intercooler and had it on and running properly for 2 weeks now and the car seems to be behaving strangely. It doesnt appear to have any power loss but there are 2 things that get me and i cant work out why!
    Firstly the turbo seems to spool a lot less, i dont know if it is because the larger more solid pipes are holding the pressure better and it doesnt need to spool as long and is holding more air or if there is an error.
    Secondly the spanner light comes on randomly a lot! It may be because i reset the ecu and its learning again or something to do with the above query but i dont know.
    Can anyone advise or help?
    May 2006
    scotland
    Doubt if the spanner light would come on when the ECU is re-learning. It is more likely that one of the engine parameters is going out of limits, maybe due to a non standard component now being in the system. Good luck!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Is it possible you have a leak somewhere Dan?
    WGAF#5
    the spanner lights there for a reason and thats why the turbos not spooling as much it could be a "soft" fault - you need to read the code
    when it appears ...this will give you an idea as to why its occuring and what the probable cause is - read the code with the pedal test if it works
    then post up the results
    Jul 2006
    Northampton
    Trim : Sri
    Quote Originally Posted by wickedwillie View Post
    I thought that may be the case but was trying to be hopeful lol
    No i made sure there was no leaks and have even upgraded to t clips all round
    How do i do the pedal test?
    The car is running fine now and not a single problem over pvs weekend but it seems like the boost sensor problem still persists
    EVERYWHERE
    Does the new intercooler flow better than the standard one? The standard ones are already supposed to be quite good, and are certainly much better than the standard ones on Ford TDCI's.
    Jul 2006
    Northampton
    Trim : Sri
    yea i believe it does, it is an upgrade bar and plate after all
    member of the smoke patrol 230bhp+
    got any pics of what you have put on the car
    Jul 2006
    Northampton
    Trim : Sri
    i dont have a pic at the moment but its the xspower one on ebay. i think the same as dean used in his conversion
    Jul 2006
    Northampton
    Trim : Sri
    Following on from this, i seem to of sorted it by accident lol. I fitted a breather filter and as the pipe goes to the tube after the maf i decided to add another ne there as a maf bypass and it works brilliant! lol
  1. intercooler?
    By justin32 in forum Engine & Drivetrain
    Last Post: 19th January 2013, 17:09
  2. Intercooler
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 12:36
  3. Standard intercooler v front mount intercooler
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 29th June 2011, 09:58
  4. Intercooler
    By user999998 in forum Engine & Drivetrain
    Last Post: 16th May 2008, 11:02
