Thread: need some pointers
    Regular Member bunsen1's Avatar
    suffolk
    Exclamation need some pointers
    1.9cdti sri 150 54 plate
    any pointers for checks on the turbo?
    think it sounds either bit loud in general and also a bit farty after kicking in.
    was playing about after fiitting the blue pipes to the vacumn and the turbo when revved sounded airy but when revs were dropping sounded strange like a possible fart lol but i know nothing so am need of a few checks
    did see someome had posted up about having a split on a white tube/pipe/hose but cant find it?
    Regular Member DaveW555's Avatar
    Cannock
    the only physical check you can easily do on the turbo is to take the intercooler pipe off and wiggle the shaft to check for excessive bearing play. It could just be that the new pipes are silicone and the old ones were rubber so the material makes it sound different (i could be wrong of course but stranger things have happened). Hope this helps. Good luck with it.
    suffolk
    i will find a how2 for the intercooler and see if i can do that
    it sounded a bit airy to me before the blue pipes were fitted and not sure about the after turbo noise,
    thanks for your response though mate
    Cannock
    it'll be the flexi pipe off the turbo, just undo the jubilee clip that secures it, pull the pipe off and you should be looking at something that looks like a fan, just give it a wiggle up and down left and right to chack for bearing play and give it a spin by hand to make sure its nice and free, thats pretty much all you can do with it matey.
    suffolk
    thanks mate
    suffolk
    what if theres toomuch play, should there be any?
    if so whats the remedy and cost if ya know?
    Cannock
    there should be a tiny amount of play like in any bearing but you'll deffo know if its too much it will flop about all over the place, its hard to say in mm or whatever how much as its something i just know from feel rather than measurements, like i say tho you'll deffo know if its shot.
    suffolk
    is it an expensive repair/job if it is to much play?
    thanks for your help
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Whole new turbo needed m8 sorry, £450 for the part.
    Gazza4
    suffolk
    ouch, maybe i wont check it
  1. Any pointers to how much these bits are worth?
    By lee866 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 23rd February 2009, 00:35
  2. Any pointers on changing a Bootlid
    By Kyser143 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2008, 16:15
  3. lowering-views/pointers/help
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2008, 23:58
  4. how your mouse pointers actually work!
    By eug4611 in forum Comedy & Humour
    Last Post: 8th August 2007, 10:25
  5. need a few pointers
    By m20_swe in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2006, 23:14
