Results 1 to 2 of 2
Thread: Alternator Voltage
    Redditch
    Default Alternator Voltage
    I think I may have an issue with my alternator with the bearings on their way out and it making a high pitched noise all the time. I have checked the output of the alternator and it is only kicking out 13.9v is this normal for the vectra, i'm used to cars that produce more around 14.6v. It is charging the battery enough, its not struggling to start etc but other peoples figure will help me before I try and claim a new alternator on warranty.
    Regular Member DaveW555's Avatar
    Cannock
    It may not be the bearings in the alternator it maybe the clutch pulley has seized up causing the noise, as for the voltage it should be putting out about 14.4v but if its charging ok and you've never had any problems starting etc its probably nothing to worry about.
  1. What voltage should the alternator be producing (3.0 V6 CDTi)?
    By ph67 in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2013, 14:37
  2. 3.2 - alternator voltage fluctuates
    By Jay-C in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2012, 14:14
  3. Vectra 1.9 CDTi 150 Alternator / battery voltage
    By trucklord in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2012, 10:06
  4. What can cause a voltage drain...
    By Penfold101 in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2010, 19:17
  5. Op-Com ERROR: B3109 - Remote-Key 1 System Voltage Low Voltage
    By Jedi in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 18:17
