Results 1 to 10 of 30
Thread: z22yh help needed strange problem
    falkirk
    Default z22yh help needed strange problem
    right best give you the full story of whats happened so far
    bought a 2.2yh singum few months ago eml light was on so cecked coded both lambda sensors were ******ed so replaced no more eml light or codes now i have a new problem and i just cant understand why its happening
    lots of blue smoke out exhaust inlet manafold full of gunge (black oiley gunge) and lots of it checked what breather hoses i can find and cleaned i just dont know how oil is getting into the inlet manafold
    just to put into perspective its burning around 1 ltr of oil per 70 miles and its slowly but surely getting worse
    any help much apreciated
    Oct 2006
    southampton
    15 Post(s)
    what year is it matey
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Take the TB off and syringe as much oil out of the manifold as possible. Then, take the breather off the cam cover, blank the intake side and put the other end in a clean cloth. Take it for a spin and see if much oil comes out the breather and if the blue smoke has stopped. Its quite common to find loads of oil in the manifold. Have you had the plugs out?
    Oct 2006
    southampton
    15 Post(s)
    Ere Rushy, how big a job to remove and clean whole manifold...
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    On the SE its not that big TBH, unbolt and unplug dipstick, TB, Vac lines, EGR pipe and ECU. I think in the Vec the fuel rail can stay in and then lastly unbolt the manifold. I'd imagine the YH would be similar but the manifolds totally different so couldn't really give you a good answer.
    This is yours mate in the YH, the pipe marked as 1 is for the EGR, where it bolts to the head is another way of blanking the EGR, you just put a solid gasket in between the pipe and head mating surface. It works on the SE, who's going to be the first to try it on the YH..............Coke can and bobs your uncle, 2 minute job and no need to mess with the actual EGR.
    Oct 2006
    southampton
    15 Post(s)
    Was thinking of an oil catch can but, apparently cant be vented to atmosphere as its a pressurised system so I would have to blank off the breather...
    falkirk
    its a 53 2004 model guys its not runny oil its thick sludge so would have to strip manafold off to clean it i havent had the plugs out yet ran out of time tonight
    i have blanked of the breather and took for a run next to no oil coming from the cam breather
    Regular Member DaveW555's Avatar
    Cannock
    if its chucking blue smoke out the exhaust its burning oil, could be a number of things, valve stem oil seals, piston rings, blocked breathers, as you say its gunged up in the manifold, id take the manifold off altogether clean the life out of it so you can eat your dinner out of it, take out all the breather pipes and check them to see if they've gone sticky (you'll know what i mean if they have) if so replace them, if not give them a ruddy good clean up and if poss take the crank case breather valve out and give that a clean as well. Put it all back together and see how it goes, if its still smoking blue smoke its more than likely gonna be stem seals or rings.
    Oct 2006
    southampton
    15 Post(s)
    Is it possible to remove the EGR completely, looks just a piece of pipe to me.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by lizard View Post
    The EGR bolts to the head, the gasses run through the head, then through the pipe into the manifold. You can get a blanking plate but it means messing about with the EGR, this way nothing is touched and its free to try so failure costs nothing.
  1. Z22YH high pressure fuel pump needed urgently!
    By simp_2.2sri in forum Engine & Drivetrain
    Last Post: 27th April 2011, 22:18
  2. Anyone with a Z22YH .. NOT had the Fuel Pressure problem?
    By ShamusUK in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 14:30
  3. Strange problem with starter, Help needed
    By platty in forum Engine & Drivetrain
    Last Post: 8th September 2010, 00:39
  4. Z22yh With a strange rattle...please help!
    Last Post: 18th October 2007, 10:17
https:www.vectra-c.comforumshowthread.php112616-z22yh-help-needed-strange-problem
Z22yh uses oil
z22yh inlet manifold removal
vectra 2.2 uses oil z22yh
vectra c z22yh using alot of oil
problems with oil breather vctra c
vectra c 2.2 petrol burning oil
opel z22yh lambda failure ecu
Signum z22yh blue smoke
z22yh excessive engine oil use
vauxhall vectra c 2.2 direct engine breather
vauxhall vectra c 2.2 direct burning oil
z22yh enginebrake enfine failure
2.2 petrol vauxhall breather problems
oil catch tank z22yh
vectra c 2.2 breather
z22yh oil catch tank
vectra c piston rings
oil breather vectra 2.2 direct
black oiley tar in vectra engine
