Thread: brake pad wear censor
    grantham
    confused brake pad wear censor
    Have just changed the front pads as the light had been on for a couple of weeks. The pads are all good, but the light is still on because i need to change the wear censor. Got one ordered but want the wear light to go out as its mot time and don't think i will have time to do it before it goes in. If i just unplug and remove the censor will the light go out???? Or can i just cut the wire so it's still plugged in. This is so i don't get loads of road scum in the plug/connector block. What's the best way of making the light go out??? Answers on a post card please. lol
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Leave it connected but cut the wires (on the sensor bit) and twist the wires together. That will stop the light until you get it replaced
    grantham
    thanks john. already got my boots on to go outside and do it. just been waiting for a reply, so i do it right. thanks again mate.
    grantham
    been out to the car cut the wires and twisted them together but the light stayed on. i also cut the wires without twisting them together but the light stayed on. WHAT SHOULD I TRY NEXT??????????
  1. Brake wear sensor put where?
    By kenp in forum Suspension, Wheels & Brakes
    Last Post: 28th August 2012, 23:33
  2. Brake pad wear sensor
    By dittohead in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2010, 22:20
  3. need help!!! pad wear censor dash light
    By gokartin in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2010, 12:57
  4. Rear brake pad wear
    By Corey in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 10:25
  5. Brake wear sensor
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2008, 20:33
censored brake pads
