Thread: Screeching noise between 1800-2500 revs
    Sheffield
    confused Screeching noise between 1800-2500 revs
    Hi All,
    Got a 56 plate Siggy 1.9 CDTi 150
    Recently had an awful noise when revving between 1800-2500 revs, kind of a screeching - like a fan belt squeal, but much worse.
    Had it into the garage cos my DMF was also shot and had hoped it was related, but not so. Mechanic tried the vac pipes and another pump - still not cured.
    He thinks it could be turbo related - any ideas? Have just stumped up £600 for DMF and had a £1000 bill for inlet manifold/egr/etc at Xmas, so really don't want ore bad news an d general money pit misery
    Regular Member DaveW555's Avatar
    Cannock
    Have you noticed any change in performance or any smoke out the exhaust? You could check the alternator pulley as these fail from time to time and make the belt do some weird and wonderful stuff, i've even seen one throw a belt off altogether, when the engine is running have a good look at the belt as it comes off the alternator and see if its flapping about or jerky between pulleys, thats a good indication that the clutch pulley on the alternator is shot. If so replace the pulley,the tensioner and the belt and it should be like new.
    Sheffield
    Not noticed any change in performance per se - although when the screeching stops, there is a small burst in power like the clutch had engaged.
    Will take a look at the alternator belt tho - cheers
    Cannock
    If you want to check the turbo the only physical check you can do is remove the rubber/silicon hose off the turbo outlet to the intercooler and check for excessive bearing play by wiggling the shaft up and down etc, you could also spin it by hand to check it rotates nice and freely.
    Sheffield
    Picked the car up and the mechanic showed me the sound going when he takes of the vac feed (car runs like a slug, but no screeching), so their likely diagnosis is the turbo. He suggested that they only see problems with remapped cars
    Would anyone like to comment? Also, can anyone recommend a good replacement turbo stockist if it is....
    F**king moneypit has begun....
    Cannock
    There's plenty of turbo places on the web, just play them all off against each other and see how cheap you can get it.
    Dec 2012
    Bideford
    Quote Originally Posted by Paul_O View Post
    I have the same symptoms with mine. Did you determine that if defiantly was the Turbo. What was the end result would appreciate if you could offer any advice😪👍
  1. Slight Droning Noise at 1800/1900 RPM
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2013, 12:36
  2. Engine stammer at 1800 revs cdti 150
    By goosey_1976 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th September 2012, 13:28
  3. Hestitation between 1500 and 2500 revs
    By Marky in forum Engine & Drivetrain
    Last Post: 12th May 2011, 20:36
  4. Screeching noise from back
    By Danialj32 in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2010, 22:59
  5. Loud Screeching noise
    By lesbo in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2009, 10:11
screeching noise from vectra engine
