Thread: faulty lambda sensor
    Regular Member stephen g's Avatar
    livingston
    Default faulty lambda sensor
    can a faulty lambda sensor cause your car to burn more petrol? i am curently doing 26.2 mpg in my 2.0 t and thats just cruising no harsh accelaration i do have a faulty lambda sensor this is why i ask .
    Yes it can increase your consumption. If the lamda sensor isn't working properly then it won't be giving accurate data and so the fuelling can't then be controlled accurately.
    If you mean you're getting 26mpg on a long run then that's not good, if you meant driving around locally/urban driving then that's about right TBH.
    Northampton, UK
    How much is the sensor? (non-trade)
    livingston
    just checked mpg on the later 2.0 turbos and they are ever so slightly better why is that ?
    Northampton, UK
    They have a different map to lower emissions or something like that. (I think)
    Jan 2006
    Norfolk
    Quote Originally Posted by n_hudson View Post
    I just bought one for a Vectra B 2.2 from here, http://www.lambdapower.co.uk/partsearch.asp cost me £67 worked fine, phoned up to order and they were very helpful, part arrived next day, quite a bit cheaper than Vx.
    Regular Member jasonmma's Avatar
    Aug 2007
    edinburgh / Livingston
    I got one for my Vec C from VauxPart on ebay (like an authorised Vauxhall re-seller) and 6 months warranty, £35 inc del
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    On round town runs on average i get 22mpg..spirited driving and bsr remap...
    Have been thinking of removing the remap to compair economy...hmmm
    Regular Member nelly452's Avatar
    Aug 2011
    reading
    if the o2 sensor is gone yes you will burn more fuel ive had this problem with a few cars , the quite cheap to replace though.
    havn mine replaced wednesday by vx...under warranty..
  1. Y can't I get my lambda sensor out
    By danno91 in forum Engine & Drivetrain
    Last Post: 31st August 2011, 18:13
  2. Lambda sensor
    By danno91 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2011, 16:06
  3. Lambda Sensor
    By Sambor in forum Engine & Drivetrain
    Last Post: 14th June 2010, 19:43
  4. lambda sensor
    By Morephun in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2008, 21:48
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
signum faulty lambda
lambda sensor getting burned corsa c
