Thread: wires in usb lead
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default wires in usb lead
    I need to wire my camera up to interior light but on the usb lead its got 4 wires, black , red , white, green is red and black to power it up? And white and green used to connect to pc?
    Oct 2009
    Sandwell
    In the interiour light connector wich hole is live? And wich is earth?
    Ely, Cambridgeshire
    58 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    USB is 5 volt NOT 12 volt, you will need a transformer to drop the voltage down or you'll blow the guts out of it.
    I bought a multi voltage cigar lighter adaptor that I took the guts out of and hard wired into the centre console to run a portable USB hard drive with. Got it from Maplin.
    Oct 2009
    Sandwell
    Quote Originally Posted by Ian-Highlander View Post
    cheers ill stick with using the cig lighter lead to power it thanks
    edit:
    would this work? wire a cig lighter to the interiour light and plug the cig adaptor that has usb slot then put the usb lead into that?
    Ely, Cambridgeshire
    58 Post(s)
    Year : 2010
    The adaptor (the cig lighter plug) you've got will already step down the voltage for it, so yes, you can, as long as the cig plug of the adaptor is getting 12v (and the right polarity ie centre pin is positive), it will work fine.
  1. What are these wires?
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2011, 14:18
  2. soldering abs wires.
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2011, 21:10
  3. ignition wires
    By ferooo in forum Electrical & ICE (including SatNav)
    Last Post: 17th February 2011, 08:58
  4. help with wires
    By simon5800 in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2009, 16:01
  5. what are these two wires for?
    By JammyBStard in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2008, 19:25
