Results 1 to 10 of 23
Thread: Illumination Wires - Yellow/Grey...
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Default Illumination Wires - Yellow/Grey...
    Are there any in or around the rear boot area or BCM.
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    BCM yes, thats there it originates from.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Or if you dont want to go into the BCM what about the number plate light. It comes on with the blipper.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Quote Originally Posted by plasma View Post
    Cheers, is there an easy way to remove the boot panels?
    I would but mine wont do the 1 blip open for some reason, tried sorting it a few times .
    If i can get a decent feed of the BCM I should be ok...
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Open the load net loops on the boot catch panel. Pull from bottom and the panel will clip off. Push the 2 or 3 plastic rivets through and the boot wall against the BCM should just pull out.
    Full Member Robsey's Avatar
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    Do you mean the BCM (Body Control Module), behind the glovebox, or do you mean the REC (Rear Electrical Centre) on the left side of the boot / load area?
    All lighting signals originate from the BCM as follows.
    Note the BCM has 78 pins set out in four rows...
    pin 17 grey/yel = Instrument illumination, heater panel etc illumination
    pin 35 grey/yel = interior light
    pin 74 grey/yel = lighter ring illumination.
    Hope that helps
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    REC , thats the one
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    I've never looked at the pin outs for an REC unit, however there must be outputs for the rear door-switch illumination, the rear switch panels for the optional rear radio head unit etc.
    Alternatively, what about a relay feed, controlled via the boot interior light circuit?
    Would it freak the CAN system out if you took a feed from a tail light or the number plate light, say to a relay so as not to overload the side-light circuit.?
    I know the pin outs for the BCM and the CIM, like the back of my hand, but this is no use in this situation
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by Robsey View Post
    Both my numberplate lights were out and it didn't pop up any bulb warning so I don't think its in the circuit. Also I've noticed that my rear wiper stops mid stroke when I turn the ignition off so I think that runs traditional relay type wiring. Adding and extra rear fog light also doesn't pop up any bulb errors.
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    As above really, number plate lights are not monitored
  1. Facelift Xenon Headlight wiring n/s yellow & white wires
    By Simon_Fuller in forum The 'Off Topic' room
    Last Post: 8th December 2012, 17:12
  2. Are there any Illumination wires in the rear...
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 1st September 2010, 22:12
  3. grey plug yellow plug?
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2010, 14:35
  4. Rear Cig Lighter... Grey/Yellow wire...
    Last Post: 6th March 2010, 01:44
  5. brown/grey-yellow wires under the ashtray
    By sig63 in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2006, 16:04
yellow wire lighting circuit vectra c
vectra cigar grey yellow wire
vectra c grey wire
vectra c illumination wire
