Thread: gasket paper HELP
    belfast
    Default gasket paper HELP
    hi, i have made a blanking plate for my vectra 2.2dti from 0.6mm alluminum, do i have to sandwich this with something like a paper gasket for a perfect seal?
    Full Member spennny's Avatar
    Blantyre
    I would say yes you do , metal on metal will not create the " Perfect Seal "
    Regular Member old cruiser's Avatar
    slough
    If it's of any help, when I blanked off mine (Z22SE petrol engine) I bought a blanking plate and gasket from VX , the gasket was probably similar thickness to your 0.6mm ally one you've made, but the blanking plate was about 5mm or so in thickness, it might be worth if it's possible, to get the right ones from vx for yours, as my only thoughts are that even if you put a e.g paper gasket between your ally one you've made and the mating surface it may still not seal well due to the flexibility of your 0.6mm plate , if you see what I mean.
    Cheers Pete
    Oct 2007
    Shropshire
    I agree with OLD Cruiser. Whilst its fine to make your own, I think your chosen matierial is too thin. I would use 3mm. And yes defo use a gasket....
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    A coke can will make the perfect gasket As long as the mating surfaces are flush and of required thickness then you will be fine.
    belfast
    great advice guys, thanks. on the thickness issue with the plate though, i think i have read it here that that thickness would be fine, am i right or wrong?
    Jan 2010
    glasgow
    on the odd time that i have made a gasket and if its not 100% mating surface u could try some instant gasket just a thin bead of it usually solves the prob
    Vehicle : SRi
    Mileage : 137000
    To check its air tight just spray carb or brake cleaner on the blanking plate while the engine is on tick over. If the revs alter while your spraying you have a leak.
  1. In the paper !
    By rob 2.2dti in forum General Chat
    Last Post: 10th January 2012, 16:32
  2. Wall Paper = Please Help = I've Run Out = Thanks
    By HITFACTORY1403 in forum The 'Off Topic' room
    Last Post: 6th August 2011, 20:33
  3. Piece of Paper for £400....
    By spoons in forum The 'Off Topic' room
    Last Post: 24th March 2009, 20:20
