Thread: EGR valve need some info
    Regular Member Martii's Avatar
    wolverhampton
    Default EGR valve need some info
    Hi ppl just had a new inlet manifold on my vectra cdti sri 150, im thinking about blanking off my egr valve, but dont know if to blank it off using the restricter plate's from vx/fiat or blank it off completely
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    I tried to blank mine off with the Fiat gasket, but ended off with a fault light, so in the end had the EGR software removed from the ECU. Everything seems fine but i'm sure ONE or two members would say it's not a good thing to do.
    Regular Member slick91's Avatar
    Jul 2009
    Newcastle
    Quote Originally Posted by mally View Post
    lol i wouldnt be so sure some lads have done it
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Yeah, i've noticed that one or two have managed with the Fiat gasket. Mine must have not wanted to play ball.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Mine worked with no EML with the Fiat gaskets, but its now completely blanked and running spot on
    PM by the way.
    EVERYWHERE
    There's a reason why Fiat's restrictor plate doesn't fully blank off the EGR gases, and it's nothing to do with putting on a MIL light.
    MAP sensor cannot operate correctly if EGR is fully blanked off.
  1. Replies: 6
    Last Post: 29th July 2012, 13:52
  2. 1.9CDTi Intake Manifold/Flapper Valve ESSENTIAL INFO
    By Phil MC in forum Engine & Drivetrain
    Last Post: 25th May 2012, 14:43
  3. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  4. swirl valve info please
    By wanna veccy in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2008, 18:45
