Results 1 to 10 of 18
Thread: Rear brake rewind...
    Chelmsford
    Default Rear brake rewind...
    Is this what I need:
    http://www.halfords.com/webapp/wcs/s...egoryId_165469
    Does the Vec have left handed pistons?
    I've heard people talk about having to modify the rewind tools to fit, is this one of the ones that needs grinding?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    THIS is the one I have, but I bought the proper adapter from Ebay. You can file down the ones that come with it though and it will fit.
    Regular Member platty's Avatar
    Jan 2008
    Paisley
    Hi mate the vec doesn't have left handed thread, This is the one you need http://www.halfords.com/webapp/wcs/s...egoryId_165469 although as you said you might need to adapt it slightly, Easily done though.
    oops too late
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    the lase tool is the one for the job its getting the correct adapter thats tricky. the one they list for the vectra is for the veccy B not the C, the adpater that works for the veccy C is this one
    http://www.lasertools.co.uk/item.aspx?cat=518&item=3484
    Chelmsford
    Cheers guys, I'll just get the Laser one and find the grinder if I need it...
    It's a bit pricey, but the alternative is getting the garage to do it... No brainer...
    Jul 2009
    Wiltshire
    I rewound mine with a pair of longnose pliers and some patience...
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Quote Originally Posted by tonyo View Post
    Save your money.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    i used the haldords rewind tool on my astra h and the tool fitted perfectly,i did not have to modify the tool or any other adapters,i do not know if the vectra c calipers are that different to the astra h
    Regular Member stuartbat's Avatar
    May 2008
    shropshire
    Quote Originally Posted by solorider View Post
    the vectra calipers are slightly different just the 2 holes are slightly closer.
    I bought the laser 1 and just filled then nipples down a little perfect fit
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    I have the laser one with the correct adaptor, i got it on ebay and was well worth it imo
  1. rear brake piston rewind
    By Troutfisherman in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2010, 19:59
  2. Rear brake rewind tool thread pitch
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 13:03
  3. rear brake rewind tool
    By wirrallad in forum Suspension, Wheels & Brakes
    Last Post: 16th June 2009, 22:37
  4. Rear brake rewind tool
    By Nickzx6r in forum Parts for sale
    Last Post: 24th November 2007, 17:37
