Thread: Hand Brake Adjustment
    United Kindom
    Default Hand Brake Adjustment
    Done the pads and discs at the weekend, does anyone know how to adjust the handbrake tension please??
    Regular Member DaveW555's Avatar
    Cannock
    I think you need to get to the back of the handbrake itself and the adjuster is on the back where the cables go into the ratchet, I've never done one so its a guess but thats where i'd start looking anyway.
    11 Post(s)
    Is there mention of it in the how2 for changing the rear pads?
    http://www.vectra-c.com/forum/showthread.php?t=15092
    It does suggest though that the handbrake should auto adjust.
    Birmingham
    As far as I am aware it auto adjusment.
    I did them last weekend too, and the tension was identical, assume its auto adjusted to "best fit".
    Bye bye Vec B
    - Hello Siggy!
    West
    It is auto adjust & should improve over a short period of time... you can help it along by holding the foot brake down then lift the handbrake up & down a few times allowing the mech to work & adjust.
    hth
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    auto adjust. aplly handbrake then press on the brake peddle a few times. release the handbrake and do the same again. if u still have probs mate get it down the garage mate.hth
    United Kindom
    Thanks for all the help, perhaps I should have looked on here first regarding the rear brake pad replacement etc before attempting to push the rear cylinders in and not wind them back...doh...all done now a treat
    Birmingham
    Quote Originally Posted by Eminox View Post
    Its OK, we have all been there and done that.......or is that just you and I?
    Yep, the forum does come in Blooming handy doesnt it!
    Bye bye Vec B
    - Hello Siggy!
  1. hand brake?
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 21:59
  2. hand brake adjustment.
    By buffallobill in forum Suspension, Wheels & Brakes
    Last Post: 7th July 2009, 18:19
  3. Hand Brake Adjustment
    By scottymf in forum Suspension, Wheels & Brakes
    Last Post: 29th September 2008, 10:01
  4. hand brake
    By JATBOY in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2006, 07:32
  5. hand brake
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 18th June 2006, 11:36
vectra c hand brake adjustment
