Results 1 to 10 of 21
Thread: 2.0 dti cold start problems
    New Member nickp1975's Avatar
    wolverhampton
    Default 2.0 dti cold start problems
    hi, i have a 2003 vectra c 2.0dti, in the cold weather the car struggles to start, i have replaced the glow plugs and they are working as they should do, and the relay has been changed aswell. the car turns over but it takes a while to catch and there is a huge ploom of smoke. I do also wait for the glow plug light to go off before starting.
    please help as this is very annoying
    nick
    Regular Member DaveW555's Avatar
    Cannock
    Check the leak off pipes from the injectors as they perish and allow air into the fuel system which effectively means you have to completely bleed the system everytime, they're dirt cheap so dont worry too much. If you get stuck pop it over to me and i'll have a look for you.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    53 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Irmscher Insignia CDTI 130
    wolverhampton
    hi Dave, i have been told that before, after it's eventually started on the morning it will be fine the rest of the day, even if left for a few hours, do you think it is still the pipes, where r u and how much would u charge to sort the pipes if it is them
    Nick
    Cannock
    yeah its deffo them pipes if thats the case nick, they only let the tinyiest amount of air in so thats why it takes all night to cause the flow back, its a common issue with the y20dth engine ive done loads of them. I'm only in Cannock and if you want me to do it I'd only charge you for the pipe and you can buy me a pint to do it
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    How old is your battery? We've had a similar problem with our 2.2DTi and after replacing the battery the engine started fine
    Cannock
    Its the leak off pipes, if the battery is good enough to bleed the fuel all the way from the tank to the injectors its not gonna be a knackered battery, the leak off pipes are a common failure on the y20dth engine, grrrrr why do people have to argue when i know what I'm talking about??!!?? I've not been a mechanic for 10 years for nothing you know!!
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    There was no argument in what Celes said, it was mearly a suggestion. There is no need to bite his head off
    Cannock
    He should have thought about what he said before saying it though really john, if the battery can crank the engine for long enough to completely bleed the fuel system how can it be goosed??? Just really pee's me off when people stick their oar in, its confuses the peeps that aren't clued up on certain things and could cost them money they dont need to spend. I thought we were supposed to help save each other money not cost it each other.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Look mate, I have simply explained what our problem was. He said "the car turns over but it takes a while to catch and there is a huge ploom of smoke." Our DTi was the same and it turned out to be a weak battery.
  1. Cold start problems?
    By Barlow in forum Troubleshooting
    Last Post: 24th February 2012, 14:16
  2. 2.2 dti cold start problems
    By MattHD in forum Engine & Drivetrain
    Last Post: 20th May 2011, 23:07
  3. 2.0 dti cold start problems
    By nickp1975 in forum Engine & Drivetrain
    Last Post: 1st December 2010, 11:33
  4. Cold start problems
    By hippo94735 in forum Engine & Drivetrain
    Last Post: 24th February 2010, 19:48
  5. Dti cold start problems
    By storey_3000 in forum Engine & Drivetrain
    Last Post: 27th August 2009, 08:49
