Thread: clutch help!!!
    Regular Member AKeeNShoT's Avatar
    South Shields, T&W
    Default clutch help!!!
    hi again,
    right guys my clutch has started slipping from around 2krpm to around 3.5krpms when on full throttle. i'm looking to replace it pretty soon,
    however i'm confused, as eurocar parts offer 2 LUK clutches for the y20dth,
    namely
    http://www.eurocarparts.com/ecp/c/Va...5d9993345&CLUK
    and
    http://www.eurocarparts.com/ecp/c/Va...5b628fb3b&CLUK
    why do they do this, and which one do i need?
    also is this the right DMF for me?
    http://www.eurocarparts.com/ecp/c/Va...b2daeb814&DMFW
    as always, your esponse is appreciated.
    kindest regards,
    michael
    Regular Member DaveW555's Avatar
    Cannock
    They are both the right clutch, its just the dearer one has the slave cylinder in the kit and the cheaper one doesn't, you need the dearer one really, the difference in price is worth it compared to the extra labour to change it at a later date. That flywheel does appear to be the right one for yours but christ is it expensive compared to a cdti one!
    South Shields, T&W
    thats what the garage said, they have invited me do find a clutch cheaper to help me save money. which is nice of them.
    he also mentioned a solid dmf, has anybody any info on these?
    Cannock
    You cant get a solid DMF, its either a DMF or a solid flywheel, a solid flywheel will be cheaper (if theyre available which I'm not sure about) and will last the life of the vehicle but will possibly cut the life of the gearbox. The vectra b uses the same engine with a solid flywheel but I'm not sure if there's a way to convert yours back to a vec b solid flywheel. Hope this sheds some light for you.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
