Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: stuttering turbo on 2.0t
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Default stuttering turbo on 2.0t
    guys after a hard day booting my car the turbo started to stutter when putting my foot down. the stuttering starts about 3000rpm, if i put my foot down slowly then the turbo spins up and delivers the power smoothly as expected..
    The car is remapped to just over 230bhp and has been fine until now.. the only odd thing was the petrol smell (only when really booting it) you only notice this with the window open.
    It has uprated siemens deka injectors and the sparkplugs are relatively new Denso Iridium plugs..
    having googled 'stuttering turbo' i can find references to a failing coil pack, does this sound right..? I have not had chance stick my opcom or tech2 on it yet, will do that tomorrow lunchtime.
    Any ideas on these?
    prestatyn
    coulb be anthing mate i have had some things go that make me think its goingto be really expensive due to the symtoms car i showin me but touch wood only been cheap things these engines seem bullet proof,i find most things that have gone wrong on have only put it into safe mode no spluutering so could be coil pack,there indival on the 2.0t but till you plug it in you wont know 100%
    prestatyn
    sorry about last post i have a wireless keyboard and it keeps missing letters and spaces out
    WGAF#5
    hi Nige,
    was the car mapped for the larger injectors -or were these added afterwards??
    it sounds like its an overfuelling issue from where its been running "hot" then when its backed off its still pushing too much fuel into the system ...
    Jun 2009
    South Coast
    it was remapped for the injectors, fitted at the same place and then the map was done...
    WGAF#5
    didnt doubt it had been done correctly Nige, but the question needed asking ...its a strange one it mabe that one or more of the injectors is either leaking or gassing back past its seals - needs futher investigation
    Jun 2009
    South Coast
    yeah its what i thought.. Opcom has just come up clear, no fault codes on the car. Will see what the remappers have to say on the matter..
    WGAF#5
    this is the problem with modern engine management it will self adapt to cope with the issue until such as time that its damaged another component...then its hand in your pocket time
    Jun 2009
    South Coast
    i have just removed the map and put it back to standard and took it up the road, no problems at all. I pulled over an reapplied the remap and set off again.. the car stuttered a little to start with but nothing like it did yesterday, it seemed to level out and stopped stuttering a few miles down the road.. unfortunately i do not have my wallet with me to fill her up and go for a long drive (its also my lunch hour).. Will give a hoofing onthe way home tonight if there is a break in the traffic to see if it come back, mind you all was fine after the remap was initially put on it only started stuttering after 100 miles of hard driving..
    WGAF#5
    it CAn take longer for faults to develop dependant on driving style conditions and other external contirbutary factors - ambient temp vehicle temp current gear and vehicle load etc - mine could/would be fine for days then .....lhm on an overtake ....made it unnerving going for an overtake and wondering if you would make it ---- replace both the solenoid valves the and a few other sensors.... finally its the recirc dump valve diaphram thats weakened and when hot softer then when cold...so replaced that and the car worked like a dream - but mine did not stutter or have a fuel smell - so yours is definitley a different fault - still potential overfueling or leak on the washers/seals on the injectors
  1. stuttering uphill
    By ALD in forum Engine & Drivetrain
    Last Post: 28th October 2017, 15:47
  2. Cdti stuttering
    By gtirobbie in forum Engine & Drivetrain
    Last Post: 23rd June 2012, 16:38
  3. Stuttering turbo
    By Ronnie-29 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th February 2012, 21:30
  4. Stuttering 2.2 Elite
    By Dogsbodyone in forum Engine & Drivetrain
    Last Post: 4th November 2011, 00:54
  5. 2.2 Dti stuttering under load - help
    By Boyden in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2009, 20:51
