Thread: i feel like james bond
    Regular Member andy76's Avatar
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    Default i feel like james bond
    with all the smoke that comes from the exhausts at idle. was 90% with oil valve stem seals as it only smokes at idle, but had it on comp and it says i have faults on bank 1 & 2 on o2 sensor and exhaust temp sensor is at fault (somthing to do with voltage incorrect) i think, so would these two things cause oil burning.
    over the last couple of days it's been dropping revs to the point i thought it might cut out.
    all this has started since having exhausts upgraded to a 3" system put on,well apart from the o2 that i snapped then solderd up and just kept fogettin to have it replaced.
    but now im not driving it now till i can get it sorted....
    Full Member Big Sig's Avatar
    What engine is this on as your profile hasn't been updated.
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    sorry, it's a 2.0T
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Take the oil cap off and put your hand over the hole and feel if there's any pressure, that can tell you if its the valve stem seals. Could it not be the turbo seals, there more likely to go first IMO
  1. Who's the best Bond ?
    By FIL 4822 in forum General Chat
    Last Post: 7th October 2012, 17:22
  2. james bond car
    By alijlacy in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2011, 19:22
  3. James Bond DB5 magazine
    By bigmac in forum General Chat
    Last Post: 6th January 2011, 21:18
  4. James Bond Xbox 360
    By Dwabo in forum Games Room
    Last Post: 11th January 2009, 19:07
  5. the new bond car
    By yorkshireborn in forum General Chat
    Last Post: 15th January 2007, 15:34
