Thread: Fault code 0340 Cam sensor malfunction
    Apr 2009
    manchester
    Default Fault code 0340 Cam sensor malfunction
    Hi, last month I replaced my timing belt on my 1.8 petrol SRI. I noticed that the wiring harness to the cam sensor was perished so I replaced the sensor. I now get an intermitent 0340 cam sensor fault code, the engine runs at 4000rpm max. I clear the code and the engine runs fine till next time the code appears. Anyone got any ideas.
    EVERYWHERE
    "I noticed that the wiring harness to the cam sensor was perished so I replaced the sensor."
    Maybe the sensor isn't the problem.
    Apr 2009
    manchester
    any ideas Diesel? could it be the belt tension?
    Regular Member DaveW555's Avatar
    Cannock
    Why change the sensor if the wiring was perished? I'd unplug the senor and check all the wires where you say its perished to see if its rubbed through on anything, could be as simple as re wrapping the wires up with some insulation tape (clean them all first with some electrical contact cleaner / brake cleaner or the like), did you use a genuine sensor as some of the aftermarket ones tend to be a bit poo?
    Apr 2009
    manchester
    Used a genuine Vaux Sensor, only started happening when I changed the Timing Belt. I'm going to check the Timing is Bob on once the rain stops. I'm beginning to wonder whether the belt tension is to tight. Clutching at straws though.
    Pretoria
    My 1.9 cdti Astra has the same fault code, changed the sensor yesterday but no change in the problem.
    Cannock
    Quote Originally Posted by otto View Post
    The belt tension wont give u that problem and if it wasn't timed up right it wouldn't run right or even at all, deffo think its either the cam sensor wiring or maybe you've got too big a gap between the sensor and the timing wheel.
    pottersbar
    i have same problem since changing sensor .wiring perished on old sensor but was running ok now want rev above 4000 rpm
    Sep 2009
    Swindon
    Check for rust on the cam shaft sprocket itself, had this before and was because of this.
    Frenchman
    Apr 2009
    manchester
    Found out the sensor was not a genuine part. After double checking all my timing marks and tension etc, opted for a genuine Sensor, hey presto fault cured. Spoke with a few diagnostic fellas each one said use genuine sensors only in future.
    Lesson learned cheapest is not always the best.
  1. Fault Code P1125 for both 1.9 CDTI's - Throttle Position Sensor
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 25th August 2013, 17:54
  2. MAP sensor fault code
    By cus2000 in forum Troubleshooting
    Last Post: 19th August 2012, 08:22
  3. Replies: 2
    Last Post: 24th June 2012, 02:11
  4. p0480 fault code cooling fan 1 circuit malfunction
    By Miketwinny in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2011, 22:31
  5. p0337 fault code crank sensor position a low>
    By rickyroo in forum Engine & Drivetrain
    Last Post: 4th May 2008, 12:20
insignia 1.8 petrol camshaft sensor
astra 1.9cdti cam sensor error after timing belt done help
vectra 1.9 cdti camshaft sensor fault
faulty camshaft sensor vectra c
vectra 1.9 cdti cam sensor fault
