Thread: cutting out after 15+ miles ??? 1.9 cdti
    leek staffs
    Default cutting out after 15+ miles ??? 1.9 cdti
    Hi everyone
    Please bare in mind that i am new on here and more used to building fast mini's than deisels. I have a 2004 1.9 cdti owened for 3 months and loved it, BUT now the problem is it cuts out after around 15 miles and won't re-start untill it has cooled down for half an hour
    this has happened twice on the motorway at @ 70mph resulting in a breakdown recovery each time, and now does it every time i use it unless i keep the fan running on it by disconecting the sender
    it does not overheat, and the fan never even gets to cut in on its own the engine will just cut out without warning
    I have looked at the inj 3 problem but i think my symptoms are different ?
    i have taken it back under a 3 month waranty 5 times but all that they have done is flush the engine out, and now the waranty is up
    the engine check light comes on sometimes but not all
    Is there a temperature sender on the block that is duff sending the signal to the ecu saying that it is to hot ???
    it does seem to be temperature related to me as when it has cooled down it starts and runs fine, but as i say it is'nt even getting hot anyway
    Any help greatley apreciated
    or it will have to go
    cheers Steve
    EVERYWHERE
    You need to get the check light code read. Then you will have a better idea of what the problem is.
    leek staffs
    Quote Originally Posted by diesel dog View Post
    Cheers mate
    just printed codes off out of the how to section and will give it a try
    when i get home, hopefully it may shine some light onto the problem
    thanks Steve
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    had same problem was crankshaft sensor failing common problem on fiat jtd (same engine) aparantly
    Regular Member DaveW555's Avatar
    Cannock
    I'd go for crank sensor they are fine when cold but when they warm up they break down, its common on loads of different cars not just vectra's, mercs eat them for fun lol (german engineering my arse lol)
  1. cdti 1.9 cutting out any ideas?
    By matreya in forum Engine & Drivetrain
    Last Post: 18th February 2013, 11:19
  2. Signum 3.0 cdti, cutting out at speed
    By Wal2705 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2012, 18:08
  3. CDTI 150 Cutting out
    By adam_starkie in forum Engine & Drivetrain
    Last Post: 23rd June 2011, 09:46
  4. My cdti keeps cutting out as soon as i past 3000rpm exactly??
    By richiem in forum Engine & Drivetrain
    Last Post: 21st June 2011, 09:41
  5. 3.0 CDTi limphome cutting in
    By kitchpoo in forum Engine & Drivetrain
    Last Post: 5th April 2006, 09:47
