Results 1 to 10 of 13
Thread: vectra sri turbo manifold gasket
    prestatyn
    Default vectra sri turbo manifold gasket
    hi this is my first post and was wondering if any 1 could give me some advice,i have a 2004 vectra 2.0t and im sure its blowing from the manifold gasket,its louder till it warms up which makes me think its not cracked but its starting to annoy me,has anyone change a exhaust manifold gasket and is it a hard job,my main worry is sheering a bolt,also will this leak effect my performance thanks
    prestatyn
    any help would be greatfully appreciated
    Regular Member signumturbo04's Avatar
    SCOTLAND
    exhaust manifold gasket is an absolute pain to change, check where the cat joins the turbo as that is where mine was blowing when it was cold.
    prestatyn
    there is soot all over the heat shield could this have come frome where the cat boltsto manifold as it seems closer to manifold if it is where the cat meets the manifold is that easier cheers mate
    SCOTLAND
    yeah thats what happens to mine the bolt holding the cat on at the bottom left rattles loose. easy to tighten with a 13mm spanner
    prestatyn
    cheers for info mate just went dow to it and now its cold i can feel gases from under the heat shield
    prestatyn
    cheers signumturbo04 as it was only you replied and alough it was not my cat bolt it was the bolt holding the turbo to the other end of the manifold cause of you i took a closer lookits now alot quiter cheers again mate
    SCOTLAND
    no problem glad i could help lol
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    thats a useful one to know...
    prestatyn
    got the bolts for 20p from a local place it only had 2 holding it on,put the 2 new bolts in,(dont touch while stupidly hot)unless like me and eager to see if it works i was planning on getting gasket changed saved about £60
  1. Egr pipe to manifold gasket
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 23rd January 2013, 19:07
  2. Is there a gasket between precat and turbo?
    Last Post: 19th November 2012, 22:11
  3. 2.0t exhaust manifold gasket
    By mann3210 in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 15:33
  4. Turbo gasket
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2012, 00:06
  5. Price for Possible Gasket and Manifold Repair = please
    By HITFACTORY1403 in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2011, 23:43
