Thread: 04 vectra 1.9 fuel filter change
    birmingham
    Default 04 vectra 1.9 fuel filter change
    Hi guys, have no problem doing most jobs on cars but cannot workout how to remove top of fuel filter housing so i can change my fuel filter. Have got a strap wrench on it but it is solid. can the fuel filter housing be removed from the shroud which is restricting access?
    Am i missing somethimg obvious?
    Ashington, Northumberland
    There is a screw down through the middle (torx head, T10 I think). remove the screw and the top will lift straight off. You will have to remove the fuel pipes first. Element will then lift out
    Admin plasma's Avatar
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    the filter container can be lifted upwards and removed after disconnecting the bottom electrical connector and top one and 2 feed pipes
    Needs to be put in a vice or such to grip it, think its done up to 30nm which is fairly tight and a right pig to undo...
    Gary is thinking of the DTi fuel filters not the CDTi Bad Gary... lol..
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    There may be a how 2!, but remove the inlet & outlet diesel pipes, with one hand above & one below wiggle whilst pushing upwards on the inner cannister! when it comes free, remove the elec connector from below, then remove the complete cannister, it is easier to lightly grasp it in a vise!! but be carefull!!!, unscrew the top and remove & replace.
    Quote Originally Posted by plasma View Post
    Haha, yes you are quite right Dean lol. The reason for my misdemeanour.....? I have just serviced a DTi today at work lol. I need to go to bed I think lol
    birmingham
    cheers guy's will have to wait till the weekend as im working will let you know how i get on
  1. 2.2 dti fuel filter change
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2012, 08:57
  2. Fuel filter change?
    By parky1 in forum Engine & Drivetrain
    Last Post: 13th August 2011, 22:24
  3. vectra cdti sri fuel filter change????
    By Mads in forum Engine & Drivetrain
    Last Post: 20th March 2011, 22:50
  4. fuel filter change vec c 2.0t
    By johnturbo in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 19:36
  5. Fuel filter change
    By juggernaut in forum Engine & Drivetrain
    Last Post: 5th March 2009, 16:18
