Thread: windows 7 help ..
    scotland
    Default windows 7 help ..
    my prob is I cant unlock the taskbar or pin shortcuts to it , tried to unlock it but the tick just wont go
    was fine up until today so god knows wots up ,
    any help would be great .
    cheers
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Are the options 'grayed out' or just nothing happens when you click them?
    WGAF#5
    are you logged on as the administrator or a user ??
    Middlesex
    Trim : SRI
    Mileage : 100k
    Here are some hints..
    Enable built-in admin account:
    1. Click Start, click "All Programs", please find and open "Accessories" folder.
    2. Please right-click on "Command Prompt" item and select "Run as administrator".
    3. Please type the following command line in to the coming window.
    net user administrator /active:yes
    Note: There is a space between "Administrator" and "/active:yes".
    4. Log off and log on the Administrator account.
    Please check if the taskbar works in the admin account. If not, try the following step:
    1. Click Start, type GPEDIT.MSC and press Enter.
    2.under User Configuration | Administrative Templates | Start Menu and Taskbar
    3. Set Lock the Taskbar policy to Not Configured
    This will then unlock the task bar should it be tied down at group policy level..
    HTH
    A
    scotland
    the gpedit is already set to not config.
    the netuseradministrator/active:yes isn't regognized
    oh and the start menu aint recognised too
    Middlesex
    Trim : SRI
    Mileage : 100k
    suspect that you have not put a space in the net user command somewhere..
    I have representated spaces with a _ to show you:
    net_user_administrator_/active:yes
    If you run that from an admin CMD box that will enable the administrator account and you can try logged in as administrator
    A
    scotland
    ok , now its ok in admin user , but when I log into my own user name its back where I started ,
    should I just try to copy all progs an files over to admin user and delete my original ?#
    Middlesex
    Trim : SRI
    Mileage : 100k
    try creating another account first as an admin type..
    is the one you currently use an admin account on that machine?
    Feb 2007
    North west
    as a none admin user the internet is much safer - do you really need to pin the taskbar ?
  1. Its doing my nut in (windows)
    By scotty84 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 14:39
  2. Windows 7
    By steve1975l in forum General Chat
    Last Post: 17th June 2009, 16:33
  3. Windows Wipers and Windows Washers
    By kevrod79 in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2009, 09:58
  4. Do your windows go down on their own???
    By Pepsi Max in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2009, 22:27
  5. dvd,windows,help.
    By wernham in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2008, 23:23
