Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Oil Change problems
    Regular Member lutontownfan's Avatar
    Nov 2009
    colchester
    Angry Oil Change problems
    Well i managed to jack up the car and get to the sump plug put on a socket and i just cannot make it move. I started to strip the thing a bit. Does anyone know how to remove it. I have already bought oil and filter from Vauxhall for £50 and no one will change it now unless they provide the oil and filter so i am in a mess with it. Oil really needs changing as its over 9 months since it was done.
    I have done oil and filter changes on all my care over 18 years and never had a problem till this one. How can such a basic stupid job become a major issue i ask.
    Northampton, UK
    I had to use a rubber lump hammer with an extension bar to turn the socket when I did mine.
    Full Member Big Sig's Avatar
    Six sided socket, or hammer one on that is a size smaller then needed, do it when its slightly warm too. Loads of people find this problem
    Aug 2009
    LEEDS
    mine was really tight! give it a good yank!!!
    Nov 2009
    colchester
    Just afraid of causing more damage to it, access is real hard have crawl under car from the side to reach the sump and is there a danger of shearing the head of the plug off??
    How would anyone get it off then.
    Quote Originally Posted by lutontownfan View Post
    Stilsons have also been used.
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    Nov 2009
    colchester
    Will have to try and do this job again i think
    Northampton, UK
    Just make sure you have a spare sump plug.
    Sodding Typical on Sea
    Why is the sump plug so tight on these cars? I have never heard of so many people stripping rounding and ruining sump plugs as on the Vectra????
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  3. Steering wheel change problems. No horn
    By Mick B in forum Electrical & ICE (including SatNav)
    Last Post: 10th June 2011, 21:28
  4. 1.9 CDTI problems after cam belt change
    By oxenburger in forum Engine & Drivetrain
    Last Post: 15th June 2010, 10:42
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
