Thread: Roof loom problems...
    Northampton, UK
    Default Roof loom problems...
    To top a really **** day off...
    I slammed the rear door of my car and the blooming rear light cluster fell out of the roof and the loom has pulled out of it.
    I'm a little miffed today to say the least, so really didnt need this too LOL.
    So, can I just cut a few millimetres off the end of the loom and solder it back on to the light cluster? Is that how its held in place to the cluster block?
    Thanks people
    Northampton, UK
    Anyone???
    Regular Member booker413's Avatar
    West sussex
    it should plug on mate, have you still got the plug?
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    think he meant he resoldered the ribbon to the plug =(block) ?? maybe wrong .....any wav does it work now ???
    milton keynes
    Good luck Nick and make sure your iron is a temperature controlled one so you can turn it down low. i once done a signum that someone had decided to pull out the rear light on , ideal if you have some spare hands on hand to do this.
    Northampton, UK
    Sorry, what I meant was the ribbon has split at the connection to the light cluster thingy... I guess the plug? Does the rear light have a plug to the loom? (Guess that would make sense) So I guess the plug is still attached to the light (DOH!)
    When the light cluster thing feel from the roof, the loom couldnt take the weight and parted where it joins the light.
    Regular Member Ollie's Avatar
    Jan 2010
    Towcester
    Engine : 1.9 CDTi (150)
    Mileage : 126000
    I would say it must have already been weakened then - the rear light weighs next to nothing. I have left my whole ultrasonics/lights cluster/sunglasses case console hanging down from the loom without a problem. It sounds like it could have been damaged during installation and that 'drop' was the last straw. You might be able to take the connector plug apart, carefully strip some plastic from the wiring loom, put it back in and clip it back together. I can't remember if it's a 'unclip/clip' type connector or if it's a 'fused-together' type. You might be able to force apart and glue it back anyway.
    I broke the loom for my rear light, whilst trying to get it out of the white sticky fabric tape securing it to the roof lining when putting mine in. I scraped the plastic off the tracks either side of the break and soldered a small piece of wire across the join then taped it all up. It was tricky but works. Good luck!
    Northampton, UK
    Well fitted a new roof loom that I forgot I had bought of a member a while a go, also managed to finally fit my Dimming mirror and rain sensor. All works fine.
    One thing thou...
    I now have an extra connection that goes to the back and a spare wire that says "Park assist" but it stops around the rear internal lights... Any idea what part of the Parkipilot its for? I have the rear parkpilot fitted.
    Mar 2007
    North East
    Speaker from what I've read recently.
    Northampton, UK
    My speaker is in the side of the boot. It is fitted into the wall itself.
    But a speaker is what I was thinking too.
  1. Roof loom
    By Rob h in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2012, 12:14
  2. Roof loom help
    By Gubmint Agent in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2012, 23:15
  3. Roof Loom or not ?
    Last Post: 17th February 2009, 17:41
  4. Roof Loom
    Last Post: 8th January 2009, 20:30
