Results 1 to 10 of 25
Thread: 2.0 dti wont start
    milton keynes
    Default 2.0 dti wont start
    HELP !!!!!!!!!!!!!!
    right changed the fuel filter and oil filter and thought while i was at it id clean the inlet manifold and egr of all the crud just got it together now and it wont start i thought it was air in the pipes as i had the 4 fuel pipes off to get the manifold off but thats not the case as there is diesel running through them.... any thought im soooo confused
    Full Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Did you plug the crank sensor back in ?
    milton keynes
    yeah everything is in its place ive checked over and over to be sure, it turns over fine no funny noises but just wont go
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    If its not a plug off,then its fuel,as a last resort,i would try some easy start in the intake while cranking it, but only if it wouldn't fire after bleeding the fuel up to the top injector union nuts,either that or tow start it.
    milton keynes
    ok cheers will give it ago and update
    Regular Member Exclusive BV's Avatar
    West Midlands
    There may be air in the fuel lines.
    Try the 'How to' below
    http://www.vectra-c.com/forum/showthread.php?t=107779
    milton keynes
    yeah ive tried this thats the first thing i thought it was, thanks anyway
    Regular Member rec's Avatar
    Jan 2010
    Bradford
    whats the mileage on the engine fella?
    milton keynes
    mileage is a touch over 117000
    East Midlands
    Quote Originally Posted by dti111 View Post
    ?Did you top up the fuel filter bowl with clean fresh Diesel,sounds like air in the system.
  1. wont start
    By wsophiecat in forum Engine & Drivetrain
    Last Post: 17th December 2011, 17:17
  2. 2.2 cut out now wont start
    By spink1972 in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 08:32
  3. Car wont start - please help
    By zafira in forum Diesel Engine related
    Last Post: 6th November 2010, 14:25
  4. Will not start then it will then it wont????
    By djconfused in forum Engine & Drivetrain
    Last Post: 29th July 2010, 21:37
  5. car wont start!
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 20:11
