Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: oil smells and seems to be topping its self up
    bridlington
    Exclamation oil smells and seems to be topping its self up
    hi, im new to this so cud be a laugh! i would appreciate any help with trying to find out what is wrong with my 53 plate vectra 2.0 dti.
    i checked the oil about a week ago and it was to the max mark on the dipstick and about half again over full, also the oil smells abit like diesel so i bought sum injector seals from the stealers and fitted them, i changed the oil at the same time and filled it to just under max but it has filled up again.
    any ideas????
    i thank anybody in advance for trying to help
    PRESTON
    not too well upon the 2.o dti, but it could be fuel blowing by the pistons on the compression stroke (not good). Is the engine breathing heavily? this would indicate worn or broken piston rings. I am assuming that the water in the header tank isnt dissapearing, if the head gasket had gone it can end up in the sump under the oil.
    Ashington, Northumberland
    Yep, you have a classic case of what is known as 'bore wash'. This is indeed where fuel gets past the compression and scraper rings on the piston and ends up mixing with the oil. It will have scored the cylinder wall to bits and the rings will have stuck with carbon deposits, to the piston. The only answer in this case is to have the engine stripped and rebored. Either that or a new lump. Sorry mate but either way, bore wash is EXPENSIVE!!!
    Oh and welcome to the site.
    bridlington
    Quote Originally Posted by barney490 View Post
    thanks for your reply, the engine is running fine not holding back or anything, no water gone from header tank but doesnt look good at all. i get a little black smoke on start up but nothing else. thanks again
    bridlington
    Quote Originally Posted by GARY3306 View Post
    thanks for replying, i think the car will have to go its only done 69000 miles what a waste. thanks again
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    I dont think at 69k its worn out.
    Think they are trying to scare you...
    bridlington
    hi i just dont understand how diesel is getting into the oil. ive done the injector seals so its got to be something alot worse! i always tend to buy the bad ones!
    PRESTON
    not trying to scare by any means, i agree that 69k isnt high mileage, but just cant figure out how else diesel can be getting into the oil. a little black smoke isnt that bad, but would indicate excess fuel. as i said, i am not completely au fait with the 2.0 dti.
    bridlington
    i am grateful for any info thanks again
    Jan 2010
    glasgow
    can u not put a dye in the derv and see if it shows up in the oil then u will know for sure
  1. Air con smells!
    By dayvo in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2011, 13:20
  2. Topping up brake fluid
    By R2XPT in forum Suspension, Wheels & Brakes
    Last Post: 1st July 2011, 11:12
  3. Topping gearbox oil up on 2.2 DTI
    By Rennie in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 15:35
  4. Topping up gear box oil
    By jamesr in forum Engine & Drivetrain
    Last Post: 30th March 2008, 14:09
  5. Topping up oil
    By jonesy_ni in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2007, 08:47
