Results 1 to 3 of 3
Thread: oil change on cdti
    Regular Member lutontownfan's Avatar
    Nov 2009
    colchester
    Default oil change on cdti
    hi i am about to try and change my oil again and if i jack my car up high enough and crawl under is it easy to get to sump nut? or do i have to unscrew anything to get to it.
    I have worked out i can do the oil filter from the top of the engine i think any help would be great. I have tried this job before but gave up maybe this time i can do it.
    Apr 2009
    Derby
    All I can say having attempted this recently is BE SURE you have the tooling to undo the sump plug. It is VERY soft and if (as in my case) it has been done up by an idiot with an impact wrench at the last service you will struggle to get it out with a standard socket. The voice of experience here says do this before adding engine flush... doh!
    It can be jacked up and on stands. You will have to fold back the under tray which is hinged and can be swung back (requires bending which could damage it but it worked for me).This is 4 torx screws.
    If you do change the filter from the top you need to move the coolant expansion tank to reach in. It will spit out loads of oil from the chamber when you remove it - probably all over the exaust... I think it has an outlet which you can attach some pipe to but i haven't tried it.
    Good luck!
    J
    Nov 2009
    colchester
    Quote Originally Posted by jong View Post
    Good luck!
    J
    Thanks very much for the help appreciate it fella.....i have sockets for sump plug. I hope it moves easily!!!! i do not use flush myself so no probs there. when i put my arm in to reach the oil filter all i needed to move was the expansion tank wiring . should get it off with a socket too. Does look like it will be messy though!!
  1. Oil Change 1.9 cdti
    By broadgates in forum Engine & Drivetrain
    Last Post: 30th April 2010, 13:12
  2. CDTi Oil Change!
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2010, 20:01
  3. V6 Cdti Oil Change
    By BIG NEIL in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2008, 12:59
  4. Oil change cdti 150
    By DG01 in forum Detailing and Car Care Discussion
    Last Post: 29th February 2008, 22:38
  5. 1.9 CDTI 16v OIL CHANGE
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 29th January 2008, 14:43
