Thread: 2.0 turbo funny noise?
    Jan 2006
    Dalriada
    Default 2.0 turbo funny noise?
    Just popped the bonnet of my car after noticing a funny noise
    When the car is idling its fine but when you dab the throttle a little there is a rattle type noise, seems to be coming from the back of the block around the air intake/turbo area, also when i lift off it seems like there is a rattle from the block itself. The rattle in the block does sound chain likebut im really not sure what the noise if at the turbo area...
    Ideas?
    BTW the car has just turned 40k and has a full service history..
    WGAF#5
    Steven,
    stick you head under the car - more probably a heat sheild fractured on its mounting
    Jan 2006
    Dalriada
    Cheers Dez, will go and have a gander once its cooled down a little
    Jan 2006
    Dalriada
    Been under the car and everything is fine.
    When it is sitting idling there is a tapping noise that it has never had before too, better get it into the garage, as i have been reading over on Z22SE that it could be a sign of the chain on the way out..
    leeds
    Had this on my 2.0T last month. In the end it was only the engine lifting 'eye'. The mounting bolts had worked loose - its located at the rear of the engine near the top - easy to get to.
    Maybe if you're lucky it might be the same.
    David.
    Full Member Big Sig's Avatar
    Quote Originally Posted by Steven View Post
    The fix for the z22 is to fit the NET's chain tensioner.
    Jan 2006
    Dalriada
    Quote Originally Posted by davidj387 View Post
    David.
    Checked everything over that could have been loose/rattling including the lifting eye and everything seems fine. Mark (gsi3.2)thinks its the balancer shaft/water pump chain so i better get it to the garage.
    Cheers for the input guys
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Good luck hope you get it sorted soon.
    Jan 2006
    Dalriada
    Quote Originally Posted by Super T View Post
    Cheers Terry. Im currently stuck working on Tiree and we head away to Olu Deniz on saturday for a fortnight, so will get it sorted when i come home.
  1. funny noise??
    By iasha in forum Suspension, Wheels & Brakes
    Last Post: 13th April 2011, 22:26
  2. Air Con ... Funny Noise?!
    By JDX-SRI in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 17:53
  3. Funny Noise
    By cooky516 in forum Engine & Drivetrain
    Last Post: 20th February 2010, 22:32
  4. Funny Noise
    By ianuk in forum Engine & Drivetrain
    Last Post: 9th November 2009, 16:56
  5. funny noise.....
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2009, 00:22
