Thread: help possible timing chain problem
    Regular Member signumturbo04's Avatar
    SCOTLAND
    confused help possible timing chain problem
    every so often my car sounds like the top end has ran dry of oil when first starting but when it was making this noise yesterday i lifted the bonnet and it sounds like its coming from the timing chain. however if you turn it off and back on again it stops. checked oil level and its fine also put na engine flush in and changed oil but still making same noise.
    any help gratefully received
    regards john
    Last edited by signumturbo04; 6th June 2010 at 11:20. Reason: forgot to say its a 2.0t z20net
    Full Member Big Sig's Avatar
    It could just be the tappets have drained of oil over night. Best to get it checked by someone who knows what to look for though.
    Regular Member vauxhall-john's Avatar
    fife, scotland
    could be the chain guides?? they are bad for going on the 2.2 petrol engines, so could be a similar idea on the turbo, hth
    Regular Member DaveW555's Avatar
    Cannock
    It could be the tappets have gone dry over night as BigSig says or it could also be the chain tensioner has drained over night and you're getting a little bit of chain rattle til the tensioner fills up again.
    SCOTLAND
    if i run it for 30 seconds when its rattling then switch it off and on again the noise stops
  1. Timing chain
    By dave_scarborough in forum Engine & Drivetrain
    Last Post: 27th April 2012, 22:30
  2. Timing chain kit please help!
    By benholden2010 in forum Engine & Drivetrain
    Last Post: 24th August 2011, 20:56
  3. timing chain
    By oldcommando in forum Diesel Engine related
    Last Post: 23rd August 2009, 19:35
  4. Timing chain??
    By wazza007 in forum Engine & Drivetrain
    Last Post: 28th September 2008, 10:02
  5. 2.2 timing chain
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2008, 15:54
