Thread: **urgent help required**
    Jan 2008
    northumberland
    Exclamation **urgent help required**
    Hiya, i have a 2003 vectra z22se 2.2 sri with 57000 miles. I bought it recently and the timing chain had been replaced etc.
    My problem/concern is this. A couple of times now when travelling the car starts making a train like chug chug chug type sound, as though one of the tyres is flat type noise. It is really loud both inside and outside the car, but only when moving. I have brought the car to a stop and No noise. Started moving and the noise comes back. Turn the ignition/engine off, restart and move off- no noise?
    Oil all at correct levels. No noise i can hear from timing chain area and the noise is not all the time,, i am worried i have bought a pig and there is something seriously wrong.
    Any help/advise would be gratefully appreciated before handing it to the stealers.
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    not sure but someone here will know
    Regular Member 74-lad's Avatar
    no where at the moment
    just a stab but dmf
    Regular Member DaveW555's Avatar
    Cannock
    Without hearing it its pretty much impossible to say for certain, all we could do is guess, best bet would be take it to the garage for a proper diagnosis (independant tho not stealers, they'll try to charge you for an engine rebuild when it could be a cheap fix).
    Jan 2008
    northumberland
    i should have mentioned that the car felt bouncy/jerky as if going up and down at the front.
    Cannock
    The thing that is getting me is that it sounds like a wheel bearing but that would be there even if you turned the ignition off and on a hundred times, and the fact that it goes away when you restart points to an engine issue, have you got any warning lights on the dash?
  1. Urgent help required.
    By floppus in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2012, 11:50
  2. urgent help required
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 18th December 2009, 18:00
  3. URGENT Help Required
    By Phil MC in forum Suspension, Wheels & Brakes
    Last Post: 4th May 2009, 13:38
  4. urgent help required
    By paul429 in forum Engine & Drivetrain
    Last Post: 19th May 2008, 16:49
  5. urgent help required
    By sulky_uk in forum General Chat
    Last Post: 22nd February 2007, 18:55
