Thread: Sticky Fuel Cap (Vec-B)
    Regular Member Led's Avatar
    Kings Langley
    Default Sticky Fuel Cap (Vec-B)
    Twice this has happened reently.
    Went to re-fuel the wife car only to find the fuel cap locked closed, pressed the lock\un-lock buttons a few times and it then opened.
    Tonight it would not open, so I had to manually pull the pin back.
    Has anyone else had this problem ?
    Not on any of the B's we have had....
    sounds like the lock servo is on it's way out..can you get behind the bootliner to check the wiring is sound??
    Kings Langley
    Yep, thats how I managed to open it to put more fuel in.
    I'll see if it's covered on the warranty, if not, looks like I'll be sitting in the boot for an hour or two.
    Can you not try the same angle as the steering rack??? or is that the warranty you mention..
    Kings Langley
    The car is booked in (under warranty) to be fixed and a new MOT all FOC
  1. Sticky oil?
    By spikeyboi33 in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2013, 21:42
  2. 'Sticky' idea.
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 16:51
  3. Santa Pod is so sticky !!
    By spoons in forum General Chat
    Last Post: 7th April 2010, 11:43
  4. Sticky Weights
    By s1nglef1sh in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2009, 19:39
  5. Sticky Sub
    By parapaul in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2006, 03:28
