Thread: Changed front pads now no brakes
    Middlesex
    Default Changed front pads now no brakes
    HI
    I have just fitted new pads (Vx Genuine ) to the front of my Signum and now pedal will go to the floor.
    1 I did not push the fluid back to cylinder I clamped the hose and bleed fluid off
    2 Have bleed system with 1 1/5 litres of fresh fluid
    3 Pedel is rock hard with engine off ( ign off and on )
    4 Start engine pedel can be pushed to floor with firm px but if pumped will go hard for a short time
    5 Car will stop and kick in abs
    Any body any ideas as have done this way before and never had a problem
    Roger
    Regular Member 74-lad's Avatar
    no where at the moment
    Hi are you sure you got all the air out,is the vac pipe connected and OK with no leaks and is master cyl OK with no leaks as this is all your symptoms point to.
    Sodding Typical on Sea
    You will need to pump the pedal a few times to get the pads in contact with the discs after them being withdrawn into the caliper, alternately an ingress of air, get someone to assist doing a bleed to ensure air isn't in the system
    Regular Member old cruiser's Avatar
    slough
    It is possible that it's an issue with air trapped in the abs modulator, in that with these systems there is often a need to activate the modulator when bleeding the brakes to ensure air is completely dispelled. Might be worth biting the bullet and getting the brake fluid replaced and bled at the same time from a local or VX garage, had mine done the other month at a vx garage and cost about £30 which was fluid replaced and bled.
    Cheers Pete
  1. Changed Front Brake Pads
    Last Post: 21st January 2012, 18:21
  2. changed pads, grinding noise!?
    By mattster87 in forum Handling & Braking
    Last Post: 16th May 2010, 20:13
  3. whoops....when changed pads
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2008, 18:58
  4. Changed front pads today...
    By hagga in forum Suspension, Wheels & Brakes
    Last Post: 15th May 2007, 12:54
  5. Brake pads and discs changed
    By bruceybonus in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2007, 23:10
