Results 1 to 2 of 2
Thread: rear interior light bulb change
    Sodding Typical on Sea
    Default rear interior light bulb change
    As the title suggests the manual says workshop but it must be possible to do this yourself?
    Any help appreciated
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    2 min job. The lens should just pull out. Be careful asit has a circuit type flexi to power. Then remove motel cover, just clipped in, pulls out easy enough. I then use a small flat blade screwdriver to prize the bulb out as there a little sheltered in the housing.
    Hint. Turn off switches and bulbs will stat cold.
  1. How to change bulb inside interior light?
    By Bamber in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2012, 20:41
  2. How to change a light bulb?
    By LAZZEE RARSE in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2010, 17:59
  3. signum rear light bulb change
    By arkhan78 in forum Bodywork & Interior
    Last Post: 8th March 2008, 14:09
how to change rear interior light vauxhall signum
