Thread: 1.9CDTi starting problems
    Hambleton, North Yorkshire
    Default 1.9CDTi starting problems
    Hi
    Im new to this forum and im hoping someone may be able to help me.
    I have a Vectra 1.9CDTi 120 which has starting problems. It starts eventually (with a puff of smoke usually, although i think this is just unburnt fuel). It is poor at starting whether cold or warm and I have changed all filters and the glow plugs so far. It has been into my local garage and a local Vauxhall dealership and been on the diagnostic machine, with no fault codes to be found. Has anyone got any ideas? Im told its a fairly common problem, but no-one seems to be able to fix it.
    11 Post(s)
    Welcome, you'd be better off asking your question in the correct area of the forum.
    Engine & Drivetrain
    http://www.vectra-c.com/forum/forumdisplay.php?f=13
    PRESTON
    welcome 3961, were the glowplugs changed as they were faulty or as an attempt to fix the starting problem?. does the glow light show on the dash at start up?might be the glow relay rather than the plugs. I have heard others with the same issue and they allow the glow light to go out twice before cranking the engine and dont pump the pedal. As with most issues on Vectra,double check all vacuum pipes for splits.
    Thanks, I'll do that
    Hi, thanks for your help. I changed the glow plugs as a troubleshooting solution, it turns out there was nothing wrong with them. The glow light on the dash does come on, not always for long, but i understand the glow plugs dont work above 5C. i have heard that split vacuum pipes and injector seals fail and cause similar symptoms, i think i'll have a go at them next. Thanks again
  1. starting issues 1.9CDTi 8v
    By Kevinw29 in forum Engine & Drivetrain
    Last Post: 14th October 2011, 08:10
  2. 1.9cdti whine when starting
    By mann3210 in forum Engine & Drivetrain
    Last Post: 12th July 2011, 12:16
  3. Vectra 1.9cdti starting problems
    By Dale1 in forum Engine & Drivetrain
    Last Post: 20th June 2011, 14:29
  4. 2006 1.9cdti Cold Starting Problems
    By rjcotterill in forum Engine & Drivetrain
    Last Post: 7th June 2011, 16:15
  5. starting problems 1.9cdti 8v
    By Turbomanrony in forum Engine & Drivetrain
    Last Post: 8th November 2010, 02:36
vectra c 1.9 cdti starting problems
vauxhall vectra 1.9 cdti starting problems
vectra 1.9 cdti fuel pump problems
vauxhall vectra c 1.9 cdti starting problems
1.9 cdti starting issues2007 vauxhall vectra 1.9 cdti starting problemsvectra 1.9 cdti not starting1.9 cdti 8v takes ages to startzafira 1.9 cdti startingc max 1.9 cdti random starting issuevauxhall vectra 2007 1.9 cdti startingintermittent poor starting astra cdtivectra c cdti starting problemvauxhall vectra 1.9 cdti not starting1.9 12 cdti bad startingvectra 1.9 cdti slow starting problemsvectra 1.9 cdti poor startingvectra 1.9 cdti 8v slow to startastra 1.9 cdti starting problemsvectra cdti problem startingvectra c 1.9 cdti 2005 known problemsvauxhall vectra 1.9 cdti starter motor problems07 vectra 1.9cdti starting problemvectra starting problems 19 cdti
